Question about Xerox DocuColor 12 Printer
HELLO- I NEED NEW POWER CORDS TO CONNECT MY XEROX DOC 12 TO THE COMPUTER TOWER WHERE CAN I GET AFFORDABLE USED REPLACEMENT CORDS? THANK YOU- KRIS BOLINE
  • 62 Answers
If cords are the power cable, then go to maplins or any place that has electrical hardware, 13 amp kettle lead is what is needed
Posted on Oct 01, 2010
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Computer was shut down and power turned off. When i restarted the system the printer and monitor came on but the tower is not getting any power. cords are all plugged in and checked outlet works. seems...
    If the outlet is good and the cord is good, you may have indeed blown the fuse in the power supply. That is the only fuse. The fuse in the power supply is usually "hard-wired". Not necessarily, but usually. You would need someone familiar with them to replace it if it is blown.
    Some computers have a green LED on the back of the computer near the power cord. Do you have one? Is it on? You can also look to see if the small green LED is on on the motherboard.
    If you get no indication of power, the power supply is probably gone. A new on is about $25 and pretty simple to replace.
    Hope this helps.
    Thanks for using Fixya.
    Feb 20, 2011 | HP Pavilion a705w PC Desktop
    Where do you plug in the telephone jack
    To connect the machine for use as a fax machine, plug the cord into the left side of your machine, lower phone jack labeled LINE and the other end into the wall phone jack. To connect a telephone to your machine, plug into top jack on the left side of machine labeled EXT. Reference page 2-12 of this link to your Xerox WorkCentre M20i User Guide.
    http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
    Nov 18, 2009 | Xerox WorkCentre M20i All-In-One Laser...
    Missing Power cord for a 52" TV Aquos, What do I need to order?
    you can use the noraml power cord which is used for the desktop computers power cable you can get in the computer accessories shop.the power cable which connects the tower cpu fits your LCD tv too.
    Oct 20, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
    I need the diferences between docucolor 12 and xerox 7132? please
    Pretty vague question.
    The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
    The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
    The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
    The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
    Jun 23, 2009 | Xerox DocuColor 12 Color Copier
    My display says turn power to printer on
    hi just try this reset code through to nvm 776-063.
    Jan 22, 2009 | Xerox DocuColor 12 Printer
    Error 3-397 Xerox DC 12
    Hello, I have a Xerox DC 12 and i receive the error 3-308
    Someone can you help me or information about me ???
    Thank you.
    Feb 22, 2008 | Xerox DocuColor 12 Printer
    XEROX DOUC COLOR 12
    Any Xerox Dealer would have them.
    They are a pretty generic power cord.
    Jan 17, 2008 | Xerox DocuColor 12 Printer
    Xerox DocuColor 12 Printer Logo
    43 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
