Question about Tools & Hardware - Others
Need a new belt 12 1/2 " surface planer model 55-5504-2
5 Suggested Answers
  • 4088 Answers
SOURCE: Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Posted on Sep 07, 2009
  • 5603 Answers
SOURCE: Belt broken on AP13 planer thicknesser.
Here is a site:
http://www.localaccess.com/1942/ryobi/ap12.html
Find the AP13 belt there... wow...$30... ouch!
Posted on Nov 29, 2009
agent91
  • 2100 Answers
SOURCE: I am trying to replace a belt on a Ryobi 10 inch
I thought one of those belts, pulleys, had a screw on the end holding a washer. Pull the screw off and the washer, and the belt should slip off. It has been a while since I have had to go in there, but I remember that much. Unless it was a hand held planer I had. I would have to go and peek at it. Check it out.
Posted on Apr 28, 2010
  • 10 Answers
SOURCE: I have a Professional woodworker
Not know exactly what kind of belt you need, you could always go to a autoparts store and find one there. Or a lawnmower parts store. Don't bother with the big box stores. A better choice would be a segmented drive belt. Like this one: http://www.eagleamerica.com/product/485-4000/table_saw_blades_and_accessories
You don't have to buy at this site, many woodworking stores carry this belt.
Hope that helps.
Posted on Jan 23, 2011
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
I need help changing the be belt on a Dewalt 734 planer.
Installing a New Belt
NOTE: No tools are necessary to install a belt. The use of a
screwdriver or other tool to pry or stretch a belt may cause
damage to the pulleys and ultimately destroy the new belt.
1. Remove the crank handle.
2. Remove the two hex screws from the top, right side of
the planer.
3. Remove the two, small cross head screws securing the
side panels to the top of the planer.
4. Lift the side panel up out of the slot in the base and
remove the panel from the machine. Notice the grooves
inside the belt.
5. Start the belt on the top pulley (P) with 3 grooves on the
pulley, as shown in Figure 22.
6. Guide the belt between the lower pulley and the height
adjustment screw (Q), as shown in Figure 23.
7. With three grooves engaged on the large pulley, rotate
the pulley clockwise. Keep pressure on the edge of the
belt to keep the grooves engaged on the small pulley.
8. Continue pressure on the side of the belt and rotate
the large pulley while hopping the belt further onto the
pulleys, as shown in Figure 24.
9. All of the belt grooves should be engaged in the final
position and the pulleys should rotate smoothly.
10. Reinstall the side cover and the screws. Do not
overtighten the self-tapping screws.
Mar 03, 2015 | Dewalt DW734 Heavy Duty 12 12" thickness...
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Need a manual for Craftsman Contractor series 12 1/2 Planer #351.23383
Go to the Sears Parts Direct web site and search for the Planer model number. I got two results, the second one had a link for the manual. Here is a direct link: 351233831 CRAFTSMAN 12 1 2 PLANER MOLDER Manual
Jul 06, 2014 | Craftsman 12 amp 12-1/2" Bench Planer...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Aug 27, 2008 | Bailey Stanley 12-920 - Block Plane
Tools & Hardware - Others Logo
50 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
