Question about Samsung HT-DS610 System
Samsung dvd/disc protection
When i power it up, it says hello dvd/disc protection then says good-bye, antone have anything i can try before i junk this
    New Friend:
This happened to us today. I unplugged the unit, waited 10 mins, plugged back in, turned back on (from the unit, not from the remote), got the same "protection" message, turned back off and on again, and that time I quickly pushed the "function" button (again, on the unit iteself) and kept pressing until I got to the "radio" function, and suddenly I could hear sound again. went back to the dVd and we can hear again as usual! Hope this helps someone. Worked for us.
Posted on Nov 23, 2012
    President:
  • 2,712 Answers
Try a hard reset: unplug from power source, remove all cabling and wait for 5 minutes before recabling.
If that fails, it is a logic board error, in which case you are probably better off buying a new device..
Posted on May 24, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
My Samsung dvd/vhs player will not stay on. Says hello, then bye a couple seconds later
Sounds like a bad power switch. When you push the power button, it will initiate the unit to turn on, but if the switch does not keep the power on to the unit when you let go of the power switch, then the unit goes into shut down mode. Then the unit will display good bye. I would have the power switch looked at first.
Aug 24, 2016 | Samsung Televison & Video
Turn system on it say hello, protection then good-bye.. whats wrong????
Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. I would take the unit in to a local repair shop and get a estimate of repair charges. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.
Hope this helps.
Aug 09, 2010 | Samsung HT-DS610 System
Regenal code dvd-p490/p490k
Hi
Power ON using Remote (no need to switch off from the back and unplug it etc...) but make sure no disc is inside. Press 'Enter' on the Remote. Then press '8, 4, 2, 6, 9'. Press 'Enter' again. The DVD player should switch off to standby and say Good-Bye, if that happens then it has become 'region free'.
Please post back for any further assistance.
Daniel
Jul 30, 2010 | Samsung Televison & Video
Samsung DVD-V5500 will not get past loading when you put in a DVD
hello,
the reason the DVD player keeps loading the disc without showing anything else is that the lens of the DVD is too weak to read the disc.
the solution to the problem is simply for you to try to use a lens cleaner in cleaning the lens, or totally replacing the lens.
take care.
May 30, 2010 | Samsung DVD-V5500 DVD Player/VCR
Hi, After a recent severe lightenung storm my Samsung DVD player is not working. When turned on it read CD/DVD Protection and shuts off. Will not open/close or stay on. Tina
Hello.. Since the problem ocurred after a lightning storm then there is a good chance that your dvd player experienced a power surge from the power line and may be seriously damaged. Try unplugging the unit fromn the wall plug and let it staythat way for 10-20 minutes then plug it in again.. if it continues to malfunction then it is probably junk.. The power down/power up reset sometimes clears malfunctions like this but not always... and especially not if a component inside it is damaged.. Good Luck..
Sep 24, 2008 | Televison & Video
Please help
I have had that problem in the past and I just pushed the DVD or the VHS button at the top of the remote. Sometimes when it is in a different mode you can get the menu but can't scroll.
Jan 19, 2008 | Samsung DVD-VR357
Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Nov 25, 2007 | Samsung HT-DS610 System
Cd player.....toshiba se-r0094
I have been having the same problemm, how can i solve this?,,thanks, Reg!
Nov 07, 2007 | Audio Players & Recorders
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Oct 28, 2007 | Audio Players & Recorders
Dvd home theatre system
When I turn on my DVD it says "welcome to samsung dvd, no disk, protection, good bye" Why? What is wrong and how can I remedy it???
Oct 18, 2007 | Samsung Audio Players & Recorders
Samsung HT-DS610 System Logo
356 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
