Question about Casio Music
Have a 2004 Casio digital piano. Makes a screeching sound when try to play,
  • Casio Master
  • 5,603 Answers
Verify the power adapter is the exact one specified. If you run on batteries, replace them with name brand ones. Just because the display lights does NOT mean the electronics are happy with the power.
Posted on Sep 28, 2010
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 | Casio Music
What is causing noises in my Casio privia Digital piano?
Pivots worn out or need lubricant. Make a warranty claim first.Otherwise, If out of warranty I would try to lubricate the hammer pivots myself. You will need "grease suitable for plastics".
Jun 10, 2014 | Casio Privia PX-350 Digital Piano Black...
Head set jack broken off in hole
I would unscrew the case to fix it only if it is out of warranty. Take it back to the dealer. Casio gives 3 years or 5 years warranty depending on the country.
Mar 16, 2014 | Casio Privia Px-130 Px130 88 Key Digital...
Casio CDP - 120 turns itself off
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
My Privia PX-3 will run fine for about an hour. After that, for example, if I am playing a piano sound and want to switch to organ, I press the organ button and the LED shows that I have chosen the organ...
This problem is NOT DIY and will likely require a trip to the repair shop... One possibility is a static discharge... Try running it for hours with no clothes on that can produce a static buildup and see if it behaves. If so, take maeasures against static... no rubber soled shoes, no wool fabrics, gound yourself to something else before touching the unit...
Aug 16, 2011 | Casio PX3 Privia 88Key Digital Stage Piano
Casio Privia px 130 One of the keys (e4) sometimes playes at full velocity even when pressed lightly. It happenes vary regularly which means I can no longer rely on the key playing softly. It is...
One of the two contacts for that key is not working. This could be dirty or damaged contact. They use a conductive rubber pills that the key presses against circuit board traces. One contact makes before the other and this is how velocity is sensed. Unless you are adept at this repair, I would recommend you take it in for repair. Chances are any part cost is negligible... mostly labor to open and access the contacts for cleaning. Clean ONLY with 99% isoprophyl alcohol and Q TIps... VERY GENTLY.
Jul 02, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
I own a Casio CPS-80s Digital Piano. It stopped playing due to something related to it's volume / amplification has stopped working. I can barely here the sound of the music, so i maintain hopes of...
You will need to contact the Casio parts department and they can provide you with an electronic schematic for your CPS-80 digital piano. This document is not available to view on the Casio website Casio Parts Department
1-800-223-2001
http://support.casio.com/manuallist.php?rgn=1&cid=008
Dec 23, 2010 | Music
Music Logo
53 people viewed this question
Top Casio Music Experts
Ben Armstrong
Matthew Spark
Matthew Spark
Are you a Casio Music Expert? Answer questions, earn points and help others
