Question about E-Machines eMachines Desktop PC
Computer turns on but the screen is black and nothing happens
  • Steve Allison
    Steve Allison Sep 27, 2010
    You always need to include model numbers of the device causing problems, not only the brand.
    Some eMachines systems use a board with integrated video, and this can even be disabled to allow the use of an add-on PCI video card.
    Before you proceed, I recommend borrowing a friend's monitor and try your system with it or bring your monitor to another computer and plug it into a different PC.
    Right now, you don't know which has failed; the PC or the monitor.
    Most monitors disconnected from the computer will flash a warning box on the screen when power is supplied that will tell you the monitor is working but that there is no input signal.
    If you are not getting such a message, the monitor is likely dead.
  • 707 Answers
Turn on
press Ctrl+Alt+Delete (Task Manager)
click applications tab
click "New Task"
type in > explorer.exe
click okay
If boots download, install, update, and run malwarebytes free version. Delete anything it catches. If log shows registry infection problem should be solved. Sometimes it works sometimes it doesn't.
Hope it helps
www.malwarebytes.org
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Posted on Oct 29, 2010
As the computer boots. The screen goes black. Nothing happens
When you mention boots, Is the computer able to POST a message to the screen or do you mean switching the computer on and there nothing POST to the screen. If your computer is able to post and then you get a black screen after that with possibly a flashing underscore symbol, then you are missing a O.s or your harddrive is currupted. If nothing is POST to the screen once the computer is turned on, then there could be couple of culprit that is causing this defect to RAM memory error, VGA, CPU, or the Motherboard itself..... The only way to test what is actually wrong is to have other hardware compatiable to test the computer itself.... would reccommend you taking it in to a computer shop since they have diagnositc tools, unless you have other computer hardware to test this with.
Jan 15, 2011 | Computers & Internet
Hi, I have a problem with my laptop(2 yrs old). When I turn it on, it shows the microsoft loading screen with the logo and all, but after that the computer screen turns black-- not completely black, but a...
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
Oct 23, 2010 | Sony VAIO VGN-C140G/B Notebook
Its an 8gb.i had it plugged into the comeputer it
just remove the any usb pen drive which is connected to the cpu and try to switch it on .if there is no display remove the ram and try to fix it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | IBM NetVista PC Desktop
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Monitor FP71E turns black
Your monitor rectifier is dead you need change transistors С5707 and check the Capasitor big one!!!!
Nov 29, 2007 | BenQ FP71E 17" LCD Monitor
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
