Question about Sport & Outdoor - Others
Lawn mower will start and will run if im pumping the bulb then shut off changed oil gas filter with air pump i blue out carb and changed spark plug still it fires up for a few seconds and shutsoff
Have you cleaned the air filter?
and it sounds like carburetor blockage.
is the fuel getting into the carburetor.?
check the needle with the float.
Posted on Sep 28, 2010
A lawn mower that gas comes out of the exhaust.
It sounds like the float in the carburetor is stuck in the open position.This will allow fuel to flow through the carb and out the muffler.
May 04, 2015 | Garden
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
Will start but want stay running gas with oil was put in mower
rebuild carb and clean thje holes in carb with compressed air to get oil out of it clean fuel tank change filter blow out fuel pump with compressdair
Apr 15, 2014 | Cub Cadet Garden
Oil in the gas tank
Not a big deal. Im assuming this is a 4-stroke push mower and not a leaf blower.
Remove the air box cover, air filter, and air box back plate. Careful there is a gasket on the back of the backplate that if damaged the primer bulb wont work, part # 272653. Remove the fuel line from the carb and drain the tank. Using a 1/2 inch wrench remove the bowl nut from the float bowl on the carb, hold the bowl to the carb as to not break the gasket seal, drain the bowl and replace the bowl nut. If you tried to run the unit and oil is in the cylinder remove the spark plug ( clean the spark plug) and spray some carb cleaner in the hole and pull the starter rope several times to purge the cylinder. Reinstall the spark plug, reattatch the fuel line, install the air box back plate ( leave the air filter and cover off for now), add fresh fuel.
Take unit outside and start, you may need to give it a shot of carb cleaner in the throat of the carb to help it start. It may smoke, it may blow oil out the muffler. Let it run until it quits smoking ( usually around 5 minutes) . Shut it off and complete assembly. It should be fine.
Oct 05, 2012 | Toro Lawn Mower With Toro Power Tools
Lawn tractor lost power while in use engine slowed down
Check for spark, if spark is present, then remove air cleaner and pour some gas down carb. not to much, then keep away while starting. If motor starts and runs then shuts off you have a stuck needle and seat or fuel pump problem.Also check oil level.
Mar 06, 2010 | Craftsman Garden
My lawn mower starts, then stalls immediately.
the carb will need to be removed and cleaned and blown out or ultrasonic cleaned is best if you can get that done? if not a can of carb or brake cleaner and blow through all the jets the blow out with compressed air
Jul 08, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Sport & Outdoor - Others Logo
55 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
