Question about Frigidaire Dryers
Can you tell me how to replace the cord from a 3 to a 4 wire plug?
    President:
  • 512 Answers
You have a block on dryer with three screws in it, the new 4 wire has black (hot), red (hot), white (neutral), green (ground) wires. Black goes to left screw, red to right screw, green and white to center screw. or white to center and green to screw holding cover that hides block.
Posted on Sep 27, 2010
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
Can u show me how to repair the stand fan motor wiring? where should i put the green color wire?
It sounds like you are working on a little pedestal fan?
and you are reconnecting the wires from the cord?-- inside the housing of the fan motor?
Why did the wires have to be disconnected to begin with?
Did you change the cord?-- or did it always have a grounding plug cord on it?
--- If it had a grounding plug (3-wire) cord before, then there should be a grounding terminal for the GREEN wire-- The other two wires (Black and White) are the supply and return wires for the 110 VAC power.
Tell us more-- see if we can figure this out!
Mack B
Jan 16, 2011 | Heating & Cooling
I need to replace the existing 3-phase (with 4 prongs) lead on my (old) defy 621s stove with a single-phase lead (with 3 prongs) as my flat is not able to support 3 phase power. Can anybody tell me how...
This is for a dryer but the range is the same...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 30, 2010 | Microwave Ovens
Changing from 3 prong to 4 prong cord
Mar 19, 2009 | Dryers
With no colour coded insulation, knowing which wire is hot
Take your old cord out. If you notice there is one side that is a little bigger than the other. Take a meter and measure the continuity from the larger side to the wire end and thats how you can tell which is which. Do the same on your new cord and that will tell you which one to put where. Like this..... ------>l l<----
o
Dec 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Dryers Logo
90 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
