Question about Magic Chef CTF1925 Top Freezer Refrigerator
I have a CTF1925DR Magic Chef that will not product ice. I have replaced the sending unit and checked for water flow but no water flows into the tray. What could this be?
SOURCE: SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Posted on Mar 13, 2008
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 172 Answers
SOURCE: Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Posted on Sep 24, 2008
  • 1122 Answers
SOURCE: Not making ice.
EITHER YOUR ICEMAKER IS BAD(IS THERE WATER IN THEWELL AREA?)OR YOUR 2 WAY WATER VALVE ON THE BACK BOTTOM OF FRIG. IS BAD(ONLY ONR=E SIDE WORKING,LET ME KNOW WHAT YOU FIND-MIKE
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: Ice Maker Stopped Working
On my three MC refrigerators over the last 30 years, this almost always meant the pipe that lets water into the icemaker is frozen. Sometimes it gets blocked (especially peas or corn). If it's frozen, use hot water and a turkey-baster type "sprayer". Do not use boiling water. If the freezer has been really active, you could have the plastic pipe in the back partly frozen, too. Be sure to shut off the water and be very very careful when moving the fridge. Some installers don't leave enough copper tubing to allow the fridge to be pulled all the way out. If the tubing gets crimped or broken, it's time to call a plumber.
The freeze-up pretty much always happened when the freezer was set too cold for the amount of food in it. When my kids were teenagers I had to unfreeze the line 2 or three times a year.
Posted on Jun 26, 2009
Ice Tray jams
PUT THE ICE TRAY IN HOT WATER ..OR KEEP THE REFRIGERATOR OPEN (EVEN THE ICE TRAY) AND LET THE ICE FLOW OUT. REMEMBER TO KEEP THE FOOD ITEMS IN A SAFE AND HYGIENIC PLACE .
Dec 24, 2012 | Industrial Magic Chef Portable Ice Maker...
Magic chef model rc203pd no water getting to ice and water outlet
yes.
please check the power supply to your water control valve.
check from the place where it receives power.
Jul 05, 2008 | Refrigerators
There is a huge puddle of water under the front of the fridge ,this unit doesn't have an ice maker what could this be ?
The drain is clogged. You will have to remove the back wall of the freezer to access the drain. There is a hole under the coils, that is th drain. Remove the ice on top of the drain and clean the drain out by forcing hot water down the drain with a turkey baser untill water flows freely. Then mix baking soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 28, 2010 | Magic Chef CTF2125 Top Freezer...
Magic chef dishwasher--no water flowing into dishwasher.
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 29, 2010 | Magic Chef 24 in. DU6550 Built-in...
Hello Where can I get the Franklyn Chef Ice
fit a universal pump from any refrigeration parts shop and you will need to set the flow rate
Apr 22, 2010 | Franklin Industries Franklin Chef Ice Cube...
Low water flow from "ice magic plus"
Have you tried replacing the inline filter? and if you have remove the filter and place a large bowel next to the water line and open it up and see if water flows from the line, if it flows fast then it's a problem with the fridge if it folws slow you have a problem with the water connection. Check that can get back to me if you need more help.
Avid101
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not Freezing
the air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Jun 22, 2009 | Magic Chef CTF2125 Top Freezer...
Ice maker problems
hi thanks for the question when you switched the wires around you checked the valves . tey are ok is the arm in the ice maker down check that if that's ok then the problem is with ice maker thanks for the question the appliance doc
Sep 23, 2008 | Kenmore 53642 / 53644 Side by Side...
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Magic Chef CTF1925 Top Freezer Refrigerator Logo
69 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
