Question about Brother MFC-9440CN Laser Printer
Good afternoon, i hope you can help me. In our office we have a Brother MFC 9440CN and it is displaying a message of 'Laser Unit End' we looked in the manual, but couldnt find anything about it...can you help??
    Scholar:
  • 107 Answers
Hello, brother recommends that the laser unit be replaced after 100,000 pages printed, it recommends that, to keep print quality normal.
Posted on Sep 27, 2010
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
Drum error message
Hi anandongol,
Kindly follow the steps below to help you reset the drum error message for Brother MFC-9940CN:
  1. Turn the the machine's power switch back on.
  2. Press Menu > Machine Info. > Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
Hope it helps.
Thank you for using FixYa.
Apr 27, 2011 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Where do I get a drum and how much is it.
You may be able to get a drum at office supply stores (they'll order it if they need to). Alternatively you can order it from Brother for $210 (rounding up) for the DR110CL drum unit. See the following URL: http://www.brother-usa.com/mfc/modeldetail.aspx?PRODUCTID=MFC9440CN&tab=supp (the Supplies and Accessories tab on the manufacturer's site for the unit). Scroll down to the drum unit and click on Buy Online.
I hope this helps.
Jul 26, 2010 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer how do i set
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Apr 03, 2010 | Brother MFC-9440CN Laser Printer
How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Sep 03, 2009 | Brother MFC-9440CN Laser Printer
Message received drum life end soon
The message means the imaging drum is going to need replacement soon. The imaging drum and toner cartridge are the two main parts that need replacement sometimes. In some printers the drum and toner cartridge are replaced in the same unit, but the Brother has separate parts. The drum is rated for a certain number of copies, so as it gets close you get the message. Replacement drums are available at big-box office places and online. An original Brother is in the $100-$150 range and generics around half that cost.
Apr 01, 2009 | Brother MFC-9440CN Laser Printer
Brother MFC 9440CN
You need to order the drum unit. It's different from the toners. You can replace it after the part comes in - you do not need a technicain to come in to do it for you. You can find the part from Amazon or Brother website.
Apr 01, 2009 | Brother MFC-8460N Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
648 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
