Question about KitchenAid Refrigerators
Not defrosting and freezer is not working. ice builds up on inside of freezer on coils. after being unplugged overnight we plug it in and it runs for about three week, then we have the problem again. it's a kitchenaid model number 395821419.
  • 2,272 Answers
After being unplugged ,it works for three weeks then the same problem again starts.and there is ice build up in the inside of freezer on coils.This is indication of defrost problem.The defrost assembly is faulty.It has to be replaced. Because the defrost assembly parts are partially faulty, so the unit is working for 3 weeks then the same no defrost problem starts.In any case the defrost assembly parts needs to be replaced. ---------- The defrost heater/thermostat and the defrost timer has to be replaced.On some newer units there is automatic defrost control board instead of defrost timer.So if there is defrost board instead if timer then replace board. ---------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 27, 2010
Freezer fan runs not freezing . seems to be locked in defrost mode
read the manual book of the freezer ,,,and see if ice is not blocking the way......
Nov 20, 2015 | Amana Refrigerators
My refrigerator is cool but not cold. My freezer is keeping things frozen but takes longer to form ice (no ice maker) and my ice cream is soft. I hear the motor running and I do not have any frost build...
Hi Nancy,
I bet you've got all kinds of frost / ice behind the plastic cover that protects (and shields from view) the cooling coil in the freezer compartment.
You probably have one or more: defrost timer, defrost terminator or defrost heating element that has failed. Call for service - or empty the fridge and unplug with door open for a day - ice will melt and when you plug in again it will work just fine. Until frost builds up again that is.
May 12, 2015 | Frost Refrigerators
The motor is running, but the ice is melting and everything in my freezer is soft. I've cleaned the coils, unplugged and plugged it back in, but so far have gotten the same results. This refrigerator...
It sounds like your defrost assembly has stopped working, which allowed ice build up (sometimes it is behind the panels and difficult to see.
To verify this without test equipment, disconnect your refrigerator from power, open the freezer door and let it completely defrost for a day. Or you can take the panel off the inside of the freezer and melt the ice with a hair dryer.
You can then plug the refrigerator back in, and if it now freezes, you have a bad defrost assembly. IThe assembly cost about $50-$100 and is not that difficult to change if you are halfway handy.
Jun 03, 2011 | Whirlpool Refrigerators
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Freezer side keeps running, other side not cold enough
Sounds like Defrost timer or circuit is not working. Look for ice build up at the back of freezer. Unplug and remove rear panel inside freezer. Are the coils covered in ice? If Yes allow it to defrost then check defrost heater, limit thermostat and defrost timer. Chances are one of these is bad. Also Check the circulating fan for correct operation.
Mar 29, 2010 | Jenn-Air Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Drain plugged in freezer
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Jan 17, 2008 | Refrigerators
MY FREEZER WORKS BUT THE REFRIDGERATOR IS INOP
ER DH is a defrost problem. You need a controller assembly which is a thermal fuse. It is located in the freezer compartment. If you unplug your unit and wait a few minutes it will reset and run for 5-7 hours until it hits the defrost cycle again. You need to get service.
Sgt 48
Dec 25, 2007 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
60 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
