Question about Cameras
I purchased a 8GB Philips mp4 player, model no. SA2VBE08K/17. I seem to be unable to transfer music from the playlist I created to the player. Everything seemed to work fine with creating the playlist on the PC, according to the instructions with the player. I just don't see an option to transfer to the player. Can you help me? Thanks.
Can't transfer music from computer playlist(songbird) to player
Posted on Jun 28, 2011
How do I turn my mp3 completely off to preserve battery life? I have a GoGear MP4 player (SA2VBE08K/17) and I can't find its manual online.
Slide and hold the power switch, exactly the same way you turn it on.
You can download the manual from the manufacturer's web site at
http://download.p4c.philips.com/files/s/sa2vbe08k_17/sa2vbe08k_17_dfu_aen.pdf
May 06, 2011 | Philips Audio Players & Recorders
Can you download music to your gogear vibe in the internet
You can transfer music from your PC to your ViBE via the software included in the product.
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?view=aa12_view_full.html&dct=QAC&refnr=0081234&slg=AEN&scy=US&ctn=SA2VBE08K/17
If this solves your problem, please come back and rate our solution. Thank you.
Dec 27, 2010 | Philips GoGear ViBE Digital Media Player
I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
Aug 18, 2009 | Philips GOGEAR SA6045 MP3 Player
Playlist dont Show
That player is set up for playlist transfer through Windows Media Player 10 only - you can either: 1) rollback your Windows Media Player to ver. 10; 2) attempt the firmware upgrade by running the Update tab in Philips Device Manager (may not work); 3) reinstall the installation CD - select Repair as your choice - it will add a plug-in that it may have skipped during initial installation. Good luck!
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips 4gb Go gear playlists
ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Nov 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
