Question about Insignia IS-LCDTV32 32 in. Television
Black square on one channel
A black square, within the picture, as if to black out the screen, appears after BRAVO! has been on for about 10 minutes. Grandchild was here and think she might have played with the remote. It looks like what might happen if you programmed in something to block out a child from watching something on a channel.
I can remove it temporarily by hitting the "Display" button but it comes back in 5-10 mins. When the TV is turned off and back on, the screen is OK for 5-10 mins but then the "black sqaure" returns. (Sometimes it has something like a line of Chinese printing on it as well.) At one point, there were several rectangles with this printing across the screen but that seems to have stopped. I have the same problem. A black square appears as if to block out the station - covers about 80% of the screen. If you press any key it will disappear for a few seconds and then reappear. I can't see anything in the MENU to fix this. Don't know what to do.
    Genius:
  • 3,587 Answers
That's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
Posted on May 24, 2008
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Black square in middle of picture
your captioning or "text" is on. usually inside the tv menu. if not its your cable or dish box has captioning on. black box usually means its in text mode instead of CC thus the black box rather than text
Jun 03, 2009 | Televison & Video
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Jan 11, 2009 | LG 42PB4D 42 in. Plasma HDTV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Check the closed caption feature in the menu setup. Consult the instruction manual about closed caption, or call the manufacture tech support.
What is probably activated is the closed caption bulletin board feature, and the station you are tuned to has the board up but with nothing on it. They use these to put text messages mainly for programming schedules and notifications.
Jerry G.
Apr 13, 2008 | Insignia IS-LCDTV32 32 in. Television
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
TV screen
make sure you lock the setting menu.
Sep 06, 2007 | Hitachi 27UX01B 27" TV
Black Box appearing on my screen
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Insignia IS-LCDTV32 32 in. Television Logo
171 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
