Question about Mitsubishi X500U Multimedia Projector
I have a Mitsubishi X500U projector which, after changing lamps and resetting the timer, will start and then go back off after about 2 seconds. The lamp lights, and when I push the "computer" button to provide the input, it shows the computer screen and then goes blank. I've pushed the main reset on the unit, reseated the lamp, and cleaned all air inlets. What's going on that I can't get this unit up and running? (New lamp was ordered through internet source)
  • sargebar Sep 27, 2010
    PRojector lights and then goes into lamp shut down after less than 5 seconds. Lamp is the same model number as the one replaced, althought neither was OEM. Is there a way to test the newer lamp or the older? Are these the only reasons the lamp won't stay powered? Power light stays on, lamp light blinks when lamp turns off.
  • sargebar Oct 01, 2010
    Looks like it's a defective lamp, either by manufacture or damaged in shipment. After reinstalling the old lamp and resetting the timer, the projector ran. Thanks for the suggestion.
  • 2,272 Answers
As you replace the lamp and reset the timer it should work.But if its not working then there are few reasons.The lamp door switch/lever is not closed properly or its loose.Check that.If its ok,then other possibility,the replacement lamp is working but its not compatible to your tv.On some tv models they dont detect compatible lamps.They see only original lamp.If that is not the cases then other possibility is that the lamp is faulty. --------- To get replacement lamp online there are few online sites. Please click on this link directly:---There are 2 types of lamp.one is original and one is compatible.the original is costly.see both. http://www.partstore.com/SearchModel/Mitsubishi/Mitsubishi/X500U.aspx ------------ There is one more link:---
http://www.superwarehouse.com/Mitsubishi_Replacement_Lamp_for_S490U,_X500U_and_X490U/VLT-X500LP/p/110321 ----------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 27, 2010
  • raj somaiya
    raj somaiya Sep 27, 2010
    Lamp light blinks when lamp turns off.This is the indication of lamp not getting detected.
    Replacing the lamp should help.Insert the old lamp and new lamp ,one by one.And see what difference it shows in the light blinking and what indication it gives.If in both cases the lamp light blinks and shuts off the new lamp is not getting detected.So get the original lamp.and check it.It will work.
    Thanks for keeping updated with your query.
  • raj somaiya
    raj somaiya Sep 28, 2010
    keep updated.Thanks.
Hi, how do i reset lamp timer on Mitsubishi XL8U?
Reset of the lamp operation time:
Plug in the power cord, turn on the
lamp, and reset the lamp operation time by keep
pressing the <, >,buttons and POWER buttons on the
control panel at the same time about three seconds.
http://www.projectorcentral.com/pdf/projector_manual_2249.pdf
May 22, 2014 | Mitsubishi XL8U Multimedia Projector
Changed the lamp of Mitsubishi WD 2000 but still shows to replace the lamp. what is the Problem???
you will need to reset the timer either in the menus under reset lamp timer or by pushing power video and computer buttons.
Jan 16, 2013 | Mitsubishi WD2000U WXGA DLP Projector,...
I changed the lamp in my sp7210 the new lamp is working fine but.
just to be sure you have the correct timer reset procedure: power the projector up, press and hold down the 2 brightness buttons for at least 10 seconds. if that doesn't work, you'll need to upgrade the firmware. go to the infocus website.
Jan 18, 2010 | InFocus ScreenPlay 7210 Multimedia...
Will not turn on
Verify the alimentation cords and the lamp continuity.
Dec 10, 2009 | Mitsubishi VLT-X500LP Projector Lamp for...
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Jul 14, 2008 | Office Equipment & Supplies
Mitsubishi X500U Multimedia Projector Logo
132 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
