Question about Kenwood VR-6060 6.1 Channels Receiver
Hello, my receiver is almost 10 yrs old. The past 2 years I've had a problem with the radio and sound actually coming out of the speakers. I usually switch through the different functions or shut the reciever on/off. The same problem applies for a disc to be played. I have a digital optical cable running from the media to the kenwwod receiver, often no sound will play unless I shut the kenwood on and off, or switch through the modes, ex. tape, aux, tuner. Any help with this issue will be greatly appreciated.
3 Suggested Answers
SOURCE: Dolby Digital Has Stopped Working
there isn't such a button on the reciever... at least if there is, it's not obvious. Where would such a button be. There is a small red LED light that comes on when dolby digital is working. That's about it. There is no mention of THX anywhere on the receiver
Posted on Jan 11, 2008
  • 27 Answers
SOURCE: Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Posted on Apr 09, 2010
I hooked Up my stereo receiver tuner to a CD player and am using 2 bose speakers Sat in a dry storage for 10 years After first hooking up sound was fine next time I turned it on speakers reverbatate I...
Foam rot, all old speakers get it, you can get them re-paired or buy a do it your self kit for 30 bucks, its happened to a few times, easy to repair and bose speakers are worth it usually
Sep 08, 2013 | Car Audio & Video
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at tss-radio.com.
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
I have an AVR 335 less than 3 years old no sound
Hello
Yes, there is something you can try, to know where to look for the problem if this happens again. If the receiver is still under warranty, just send it back, otherwise, open up the amp and trace the path back from the speaker channel to the capacitors on each channel, this is usually the problem(you should be able to see if it is blown, cheap to repair).
If all the channels went out at the same time, there is something wrong with the central unit, to repair that, if it is not the above problem, cost expensive.
Hope this can help you.
Kind regards
Andrea
Nov 09, 2009 | Harman Kardon AVR 335 Receiver
Radio isn't as loud as it should be.
I rekon yer radio is stuffed if ya don't git a new one you'll have to leave the trim tab on when using the radio.
Nov 16, 2017 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
No sound
you simply have a speaker shorting in your car. Either an old speaker with a bad voice coil (short) or a speaker who's contact(s) are touching metal. This type of short or grounding will cause the internal audio amplifier to shut off to protect the radio's output circuit. To diagnose which speaker is the culprit, you'll need to disconnect all speaker leads from the radio and one by one re-connect them until the output shuts down again. The safe way to check is with a voltmeter. If you connect one side of your voltmeter to ground and test each speaker wire lead for continuity, you'll hear an audible "beep" whe you find the grounded wire/contact. A professional car audio shop can diagnose this for you if you're still having difficulty. Hope this information was helpful.
Sep 28, 2008 | Pioneer DEH-1800 CD Player
Motorola T5000 Two Pack 2-Way Radio
Could be due to air blowing the mic or something but please remember that usually transmissions are fuzzy,
Sep 27, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
Kenwood VR-6060 6.1 Channels Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
