Question about Kicker (ZX750.1) Car Audio Amplifier
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
    Scholar:
  • 99 Answers
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Posted on Jan 04, 2011
  • 1 more comment
  • wayne
    wayne Oct 16, 2013
    the specker pops and cracks when I smack my hand on the box
  • Richard Moreno
    Richard Moreno Oct 25, 2013
    i have the same problem
  • Richard Moreno
    when i turn my stereo on the amp turns on in protection mode first then it switchs to power then the light dims out ..i get no bass output in high volume or low volume..pleaase help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
My amplifier is out of safety mode but specker pops and distorted
Posted on Oct 16, 2013
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
Hello. My Kicker kx200.4 is acting funny. The red display light on front/top of the amp is turning on for a second and then turning off, repeatedly. The light on the side (power) is also turning on, red...
the amp is a 200 Watt by 4 im guessing and its doing that because its going into protection mode unhook the subs if it stops then 1 you have a bad sub or 2 the subs are too much for the amp if an amp is rated 200w per chanel its 200 max about 75 rms or 75 normal constant power
Feb 05, 2010 | Kicker KX200.4 Car Audio Amplifier
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker zx1000.1 green light flckers and the turns red and then does the same thing over and over
seems like a protection feature kicks in and out
check your fuses and possible but a bigger size in and also check your wires make sure your ground is tight
May 17, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
KICKER AMP
sounds like a bad ground or power.
Jul 12, 2008 | Car Audio & Video
Car Audio & Video Logo
574 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
