Question about Hitachi Nr90Gc2 Cordless Gas Framing Nail Gun Clipped Head Nails 50 90mm + 2 Batteries
On my nr90gc2 nailer the firing pin does not return after firing a nail. Have cleaned ,changed o rings, lubed.
  • 232 Answers
SOURCE: It will double fire sinking second nail only half
the pin pushing your nails is loose and the guides are warned .
try to change the guides and you will see that this problem will will be gone .
one last thing , make sure the coils are in good shape as it may create some feeding problems and push 2 nails at once
Posted on Sep 26, 2009
  • 73 Answers
SOURCE: pin to drive nails does not return
the piston that drives the nail is commonly known as a single acting spring return meaning air pushes the piston and the drive pin down driving the nail in and a spring is supossed to push the piston and pin back up to load the next nail the springs are not usaly very strong so lubrication could be the problem as well try using some "air tool oil " available anyplace airtools are sold do not use wd-40 or engine oil while these may offer temporary help they will come back to haunt you if a good oil doesn,t sole your problem then its "spring time" although they have lots of safeties built in when working with a problomatic nail gun please be careful high presure air risk of injection fast moving projectile again risk of injection Good Luck
Posted on Oct 09, 2009
  • 12 Answers
SOURCE: bostitch roofing nailer wont return driving pin but moves freely
If the driver moves on it's own then it's o-ring is shot,replace it. Pop the feeder cap and clean all the roof crud that's built up underneath it.Now you can see the feeder spring,check to see if broke or old and replace.The feeder plunger is air assisted so hook the air up and depress it, it should depress hard and pop right back up. If not it needs to be cleaned and new o-rings. If this doesn't work then it's a new feeder plate you need. good luck.
5run7
Posted on Oct 14, 2009
  • 382 Answers
SOURCE: Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Posted on Jan 22, 2010
kb8dns
  • 494 Answers
SOURCE: my hitachi nr 90 gc nailer was always slow to fire
Trigger may be dirty, as an electrical switch the contacts can be intermittent. Also check to see if the safety plunger is set to correct depth and moving freely. Dirt can build up here......
Posted on Feb 14, 2010
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
My hitachi nail gun NR90gc2 will not fire
Check the date of the bottom of the gas. With the gas removed when you fire it you should hear a faint spark sound from the top. If gas is in date try putting it in your pocket for 10 minutes to warm it up. Open the front and make sure the piston is pushed all the way up into the machine.
Nov 17, 2012 | Hitachi NR90GC2 Cordless Gas Clipped Head...
When you pull the trigger air comes out near the trigger and no nail is fired.
The problem that you describe indicates that the orings within the trigger failed. You could replace the orings if you have a source for very small rings (2mm x 1.5 for the firing pin inside the trigger valve) or just replace the whole trigger assembly (under $10). Lube all orings with white grease or silicone paste lube (remove head and lube head valve assembly). Good luck
Oct 11, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
My Bostitch nail gun just start the end of the gun don't return the start place please help .
remove the piston cover screws and slide the piston out by pushing back the firing pin clean and oil all seals and o rings this area tends to collect dirt and sand and should be cleaned periodicaly
Jan 09, 2011 | Stanley Bostitch Nail Gun
Paslode compact nail. the firing pin will not return
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 19, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
Paslode framing nailer will onley fire one time and wont return to fireing pos. fires first nail great . started this problem after cleaning
Did you remember to lube the upper cylinder, lg 0-ring and silicone the striking pin----sticking may prevent returning to firing position
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
When I fire my im250 the firing pin often does not retract fully, so not letting the next nail to progress. I regularly clean and lub the gun and it fires all the time so the problem is not at that end of...
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Jul 30, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Jan 01, 2009 | Tools & Hardware - Others
Hitachi Nr90Gc2 Cordless Gas Framing Nail Gun Clipped Head Nails 50  90mm + 2 Batteries Logo
57 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
