Question about Gateway 450ROG Notebook
Charging problems my laptop wont charge. its not the battery or the plug.. its internal and i dont know how to fix it..
  • joe declair Dec 19, 2008
    i have model 475m the battery is good the power cord is good the computer works when a charged battery is put in but won't charge when plugged in--we have another gateway so we charge the battery on that one then switch batteries this is getting old gateway is in bankruptcy and can't get any answers
    mr guru whisperwolf did you know that gateway has no tech support because of bankruptcy i suggest mr guru you come up with better answers if your gonna respond
    Scholar:
  • 110 Answers
It's not something you should try and fix yourself. If you've eliminated the battery and the charger as being the source of the problems, you will need to return it to Gateway to get it fixed. If you try to fix it yourself and do something wrong, you will invalidate the warranty on top of everything else. Better to be safe than sorry.
Posted on May 26, 2008
I have a sylvania portable swivel screen ..sdvd7027 and i need to know how this will charge battery i have a plug in cord but i dont have remote or cigg plug but as soon as i unplug cord it dies ...?
sales brochure says it has a battery
best guess a lithium type
but can see any for sale ..as a single battery replacement
for one
if you didnt have to fit a battery it will be inbuilt
if new will take some time to charge it up
if not charging will be the wall plug adapter or battery failure or an internal failure of the charging section of the devices circuit board
Amazon com Sylvania Portable DVD Player SDVD7027 7 Inch Swivel Screen...
Oct 13, 2016 | Sylvania Computers & Internet
It dosent charge pass 66%.i relli dont know why and what i should do.....it says charging while plugged in but still dosent go pass 66%
Hi! Welcome to www.fixya.com.
Firstly, Check the manufacturer battery test. Secondly, Call your manufacturer and get a replacement for your battery.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 17, 2011 | Computers & Internet
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
Hi i have this problem i dont know if its bad or not but every night i turn off my lap top and let it charge over night then this morning when i log on to my user my battery says 4% plugged in, not...
This can be a couple of things. The battery, the charger, the internal charging circuit, or the connector.
The battery is not that old but just enough that you could see problems depending on how you use or charge. If you drained it a lot or never used it on the battery this can happen. If the battery was the problem then you would see very short run times when it was fully charged. For example it may run down in say 10-15 minutes or less. The battery may still be under warranty. If you feel a hot spot on the bottom of the laptop after charging overnight this usually means the battery has a problem. The heat is from the charging circuit working pretty hard.
The adapter or charger can be bad but rather rare for it to happen. Usually they work or they don't. Again should be under warranty.
The internal charging circuitry can be having a problem. Not common at all but it happens. Again will be covered by warranty.
Last is the charging plug. This is the connector where the adapter plugs into the laptop. If the plug has been damaged or is loose it won't charge properly. The way to check this is to plug the adapter in and then gently move it around if the plug moves or doesn't feel secure then this has a problem. Usually when this happens the lights on the laptop may flash off and on as it makes proper contact. This may be covered under warranty. When it isn't they will say it is user abuse.
It may take you a bit of watching to see what the problem is. It could be a one time thing ie the connector wasn't plugged in right. It can be a bad battery. Batteries can go quickly but normally they fail fairly slowly over time. You need to check if you have warranty. All of this should be covered on a ~18 month old laptop but you may only have had a 1 year oem warranty.
If you have to pay for anything a battery is $40-$80, a power adapter about $50. The charging circuit requires a new mainboard and the plug depending on the model either requires a new mainboard as its built in or the plug is a seperate piece which can run from $5 to about $100. The battery and the plug are the most common cause for this type of problem.
Sep 05, 2010 | HP Computers & Internet
My laptop dosent hold a charge. everytime i charge up my laptop i have to play around with the charger to get it to charge and the charger is brand new so its not the charger. and when it says its fully...
Sounds like the Battery or Battery contacts, You should figure it out from there. Its up to you to decide the best way to sell or trade your laptop if you desire.
Sep 15, 2009 | Computers & Internet
Lenovo 3000 N200 battery not charging.
I just had the same problem. My battery had discharged to less than zero and would not start even though the power plug was in. I tried everything... but what fixed it for me was to remove the power plug, remove the battery, plug in the power cord and start the machine. Once the machine was already booted, I put the battery in and it started charging. Dont know if that will fix your problem, but it fixed mine.
Sep 05, 2009 | Lenovo 3000 N200 Notebook
XPS M1330 issue -- laptop won't charge battery using power adapter which has been replaced. The unit will only work with the power adapter plugged into electrical outlet. How can I tell if it is truly the...
Try another known working battery in the laptop and see if it charges, if it doesn't then its going to be a problem with hairline cracks in the dc jack on the laptop. The solder points underneath the dc jack if they have hairline cracks in them won't allow the battery to charge. Basically the laptop would need to be taken apart and the motherboard taken out.
If you have soldering skills, all that needs to be done is to put new solder on the solder points that hold the dc jack in place.
If after you do this the battery still wont charge then you know for sure the connector is bad and then the connector would need to be replaced.
Aug 20, 2009 | Dell XPS M1330 Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Toshiba Laptop wont work unless plugged in, i recently bought a new battery think that the battery was the problem and still it doesnt work unless its plugged in. please help me!
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
May 13, 2008 | Toshiba Satellite P105-S9722 Notebook
Turning on problems..
Hi
try removing the battery and plug in the AC adapter try to power up, what happens?
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you,
Ekse
Apr 10, 2008 | Toshiba Satellite A25-S207 Notebook
Gateway 450ROG Notebook Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
