Question about Dirt Devil CE6000 Featherlite Wet/Dry Vacuum
My machine will not spray the cleaning solution, how does the solution get from the tank?
My Bissell proheat 2x cleaner will not spray the cleaning solution
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray we would recommend having your machine inspected by a technician at a local BISSELL Authorized Service Center.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Apr 19, 2011 | Vacuums
No water when i start the machine
Nov 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
The machine is not spraying water or cleaning fluid out bissell pro heat 2
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell Proheat 2x cleaner which has worked perfectly on every occasion. Today I filled the machine as usual with water and formula and switched on, the motor ran, the lights were on and the...
If these suggestions do not resolve the issue contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Bissell will spray water when set to water rinse, but as soon as it is set to light, normal, or heavy cleaning, there is no spray. I have tried priming but to no avail. I put plain water in the solution...
If these suggestions do not resolve your issue, contact BISSELL Consumer Services.
1-800-237-7691
Sat: 9am to 8pm ET
I have bissell cleaner 8920 it will not release the cleaning fluid and water
If your machine continues to not spray, contact BISSELL Consumer Servies at...
1-800-237-7691
Sat: 9am to 8pm ET
Aug 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The Bissell is not dispensing water or cleaning solution.... The silver & black spinner does not spin
Check the following with liquid in both tanks.<br /> <br /> - Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.<br /> - <b>Check for debris on spray tips</b>. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access. <br /> - Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE. <br />- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.<br /> - Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.<br /> <br /> If the machine continues to not spray, check the following:<br /> <br /> <b>REMOVE THE COLLECTION TANK</b>:<br />&bull; Make sure the unit is set to water rinse<br />&bull; Remove the smart mix bottle and fill it with water only<br />&bull; Place the smart mix bottle into the collection tank reservoir<br />&bull; Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.<br /> <br /> If your machine continues to not spray, contact BISSELL Consumer Service at <a href="http://www.bissell.com">www.bissell.com</a>
Aug 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
My bissellproheat2x not sucktioning
If your machine continues to not spray, Contact BISSELL consumerservices at www.bissell.com.
Nov 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dirt Devil CE6000 Featherlite Wet/Dry Vacuum Logo
124 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
