Question about Nikon Science & Laboratory
How do you detach the Labophot objective turret ?
  • 3 more comments
  • steven_dikma Sep 27, 2010
    I would like an answer rather than referring me to a web site to send an instuction manual that may or no have the answer.
  • steven_dikma Sep 28, 2010
    Thanks. I seemed to have use the incorrect term. I need to find out how to remove the entire dial (which I referred to as the turret), not the objectives.
    Thanks. I seemed to have use the incorrect term. I need to find out how to remove the entire dial (I referred to as the turret not dial), that holds the objective lenses from the Labophot Nikon microscope not the objective lenses.
    Thanks for the manual.
    My microscope has a nose piece ("dial") that is attached to what appears to be an intermediate tube. There is a small dimple on the left of the intermediate tube that looks to be the site of a screw but is only a recess. I cannot find any way to release the nosepiece from the intermediate tube or to remove the entire intermediate tube and nose piece together.
    Found the answer. Inside the intermediate tube there is a metal washer that seats the housing around the internal lenses. Removal will detach the nosepiece.
    Thank you.
  • 8,197 Answers
The objective turrets are just screwed on. You will have to hold the dial then unscrew the turrets one at a time.
Posted on Sep 28, 2010
  • 10,865 Answers
How do I sight in a Duplex Reticile scope?
Focus the reticle on the blue sky or a wall or painted surface until its sharp with the ocular focus ring
Then set the objective to 100yards or the distance you want to zero to
Shoot a group and adjust turrets and repeat until zeroed
Oct 21, 2014 | Tasco World Class 416x40 Riflescope (Matte...
The turret is out of center on sl25mc lathe
The front turret bolts will need to be removed. Remove bolts in face of turret. There should be some adjustable bolts that will allow you to move the turret back in the correct position. Load a precision ground block into OD tool holding slot, usually tool 1 position. Hang it out around 4 inches. Indicate this block within .0005 or as close as you can get it while tightening the set bolts. It usually takes a couple of tries. Also the spindle might be knocked out as well. You can check spindle by cutting between centers. If it cuts tapper then it is also out of alignment. Hope this helps...
Dec 20, 2013 | Samsung Tools & Hardware - Others
Hello, i need the software for the Konus Pix-4 Digital Microscope 100x 200x 300x / VGC.It is very difficult get it.Please help!!!MZ
If it is the same software as provided for a 100x200x450, it is distributed by ArcSoft. Maybe check: https://pulaskicotech.wordpress.com/tag/arcsoft/
Nov 18, 2013 | Konus 5023 model Konuspix 450x Digital USB...
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
Is there a way to lower my turret after i've found my zero? my zero is at the 4th vertical tic mark on the 0.
No. The turret is what it is. If you want to re-set the turret to zero so that it is easy to return to for a specific distance, there should be a setscrew you can loosen, adjust the turret to zero, then re-tighten to lock it in place. If you are simply trying to lower the turret, you need to purchase a scope without target turrets.
May 24, 2010 | Leupold Long Range/Tactical M1 Mark 4...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Remove collector and open base of Nikon Labophot
send an image of your microscope so that I maybe could help you,my email address is:r.chitchian@yahoo.com
Feb 18, 2010 | Nikon Science & Laboratory
Eyepiece and objectives - they seem to be loose.
sir,
There is two kind of eye-piece in microscope one is (push in ) and second one is tread mounted.
As per my i know you have push in eye piece.
See in side that cylinder where you are pusing in this eye piece there is two jows is there it resist to come in as well as when you take it out.that pressure of jows you should be increase.
your problems will short out.
INDRAVIJAY
Jan 10, 2008 | Premiere Microscopes MRJ-01L Microscope
Science & Laboratory Logo
262 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
Don A
Don A
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
