LG DVB418 firmware upgrade
I downloades the file "dvb418_firmware.iso" to do a firmware upgrade. After I put the disc on the machine, it says on the screen to remove the disc and press the "UP" key on the remote. Now...where is that key??? I don't have an "UP" key on the remote!!!
2 Suggested Answers
  • 259 Answers
SOURCE: Snowy reception on TV with LG DVB418
have you got both cables going into your video ?? if not you need a video splitter to input both the digital and analogue aerials then have a coaxial cable going to the tv
Posted on Mar 08, 2009
Need a firmware update for Pioneer elite BDP 05FD
The current firmware update for the Pioneer BDP-05FD is available from Pioneer: . Click on the Firmware tab then download the .zip file (titled firmware upgrade). Extract the contents of the file.
Burn the .ISO file that is inside the .zip file to a new CD-R (or CD-RW) using your burning software. (If you have Win7, you can use the included burning software to do this. Just right-click on the iso in the file explorer and choose Burn Disc Image.)
Then check that the disc has the needed files and that the files are the correct size: DLfile.pkg 95.3Mbyte (99,942,480byte), .DLdiscidentifier.txt 93byte, DLdiscidentifier.txt 93byte (for v1.71)
Then put the upgrade disc into the player (work with the controls on the front of the player instead of the remote). Then wait until the disc ejects (do not power the unit off or unplug it). Remove the disc and then turn the unit back on. You should see various information show up on the screen that will indicate that the upgrade is in progress. If it doesn't give the prompts, then you may have an unreadable CD. Try burning a new disc at a different write speed (lower); try using a different burner/computer if problems persist.
I hope this helps.
Aug 05, 2011 | Pioneer Televison & Video
I burn the DVD fine and can play it back. But when i put the DVD into another dvd player or my laptop it says the disk is empty?
You MUST finalize the disc or close the session after you are done burning a disc. If you do not do this the disc can become unreconizable to players.
Mar 20, 2011 | LG DVB418 DVD Player
I press close on the DVD player it closes then reopens it's self.
Hello there,
i have had that happen to me all the time i think the button on the remote control is sticky how we can find out is by pushing the close button on the front of the DVD player , if the DVD player closes and doesn't reopen we found the problem if the same problem happens again,
try Resetting the Power to the DVD-Unit it self by removing the power cord and plugging it back in thank you and please rate.
Jan 23, 2011 | LG DVB418 DVD Player
5.40 firmware upgrade for model bdp-s300 doesnt finish
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
The link contains the 5.5 update and it includes the functions providing the 5.4 update. Hence it is not required to install 5.4 before installing the 5.5.
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Oct 03, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
After upgrading to firmware 5.51, my psp doesntrecognized iso and cso files
Its just because you upgraded your psp into Official Firmware which dont alow you to run any homebrew application or downloaded games. You need a Custom Firmware to run iso and cso files.
Jun 22, 2009 | Sony PlayStation Portable (PSP) Console
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
Mar 08, 2009 | LG DVB418 DVD Player
Update with disc model BH100
Download the firmware file and how to document here:
Follow document to create a disk, and update the firmware.
Dec 29, 2008 | LG BH100 Blu-Ray Disc Player
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
