Copier Panasonic DP-C405 has a code U29: replace drum magenta, cyan. These have been replaced and one is not even empty and the error code still exists. How do you clear this error code?
  • 120 Answers
SOURCE: Replace drum error
Hit the clear button with the front door open. this i believe is to clear drum counter. just follow the directions that came on a piece of paper with the drum.
Posted on Feb 16, 2008
SOURCE: Panasonic Copier Error Code
This error code is a High Voltage Leak Code.
One of your charge wires is probably broken or the charge unit needs to be replaced.
You can try to locate parts from www.precisionroller.com . They might have the parts you need for your machine.
Hope this helps.
Good luck.
Mac
Posted on Mar 04, 2008
tech435
  • 284 Answers
SOURCE: Error code J93 on a
it means the paper remains in the ADF [top part of the machine] . sounds like a stuck or bad sensor
Posted on Oct 02, 2008
  • 22 Answers
SOURCE: Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Posted on Dec 07, 2009
iservice
  • 318 Answers
SOURCE: can not clear replace drum soon error New drum
Open the front cover of the machine press and hold the clear button,on the display "Srum replaced" will be displayed select yes.
That will do it
Testimonial: "Thanks that cleared the code"
Panasonic dpc264 error u29 what is this
u 29 requires you to change drum unit, as this is a general instruction, the control panel would say which drum it is. there should be instructions in the front cover, if not there usually is supplied with the drum depending on your supplier, but yes one of the drums needs two be replaced.
May 03, 2010 | Panasonic DP-C264 Copier
How do you identify the drum unit colour, so you can replace them?
Remove the waste toner box in the front the drums are behnd that. Yellow Y Cyan C Magenta M and Black K.
Feb 19, 2010 | Panasonic DP-C264 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Error codes E00020-01b0
you need to replace your yellow drum unit with a new one, error code is as follows E020-01(yellow), -02 magenta, -03 cyan, -04 black. for future referrance
Jun 05, 2009 | Canon imageRUNNER C3200 Copier
I need an Instruction manual for Panasonic model DP-C213
the drum must not be touched when inserting into device, this releases a flag and the u29 code will still appear. try another drum where the "flag" at the rear is in it's correct position.
Apr 25, 2009 | Panasonic DP-C213 Color Copier
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
PANASONIC DP C322
try another, the reset mechanism on the drum is not working. drum is good, technician will have to reset
May 22, 2008 | Panasonic FP-7760 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
371 people viewed this question
k24674
jasbo
jasbo
