Hp 5550 When printing the pages are coming out with lots of yellow toner all over the pages.
  • twingfiel341 Sep 27, 2010
    Other than the toner cartridge what could cause this type of defect
    Thank you
  • 2,272 Answers
Remove the yellow toner out and see.If there is any yellow toner got spilled out on the toner cartridge.just clean that toner with dry tissue paper and reinsert the cartridges. Also if the toner cartridge is empty then it will leak the toner on the printing paper from the waste toner collecting side in the toner cartridge.Get your toner cartridge refilled or replace the yellow cartridge.This will solve your problem.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 27, 2010
  • raj somaiya
    raj somaiya Sep 27, 2010
    Its the toner related fault.as per the problem.
    Thanks.
    President:
  • 1,139 Answers
Hi there, this is usually associated with a faulty toner cartridge. One reason for them becoming faulty is when using refilled/refurbished toner cartridges. I would suggest removing all the toners and thouroughly inspecting them for any signs of leaking. Make sure the cartridge area is also clean of toner material as this can be transferred to the pages as well.
Hope this helps
  • Kevin Penn Sep 27, 2010
    The only other thing really that can cause an image defect is the fuser, has this been changed recently?
Dirty pages
sounds like a dodgy black toner - is it a 3rd party toner - had this quite a lot myself at work with cheaper cartridges. to print a cleaning page just flick through the menu to diagnostics or print quality - in here you should find some cleaning tools of the machine
Oct 11, 2013 | HP LaserJet 5550 Printer
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
Our Hp 5550 prints thin vertical black lines on high res images. They are evenly spaced (3cm apart on an A4 print).
This is caused by a damaged drum. The drum is the long metal cylinder inside the toner cartridge. You will have to replace the hold cartridge. You should be able to flip a plastic cover on the toner and see the drum. If it has black toner lines then it usually means the drum is scratched and there for toner fills the scratch and produces lines.
Replace the print cartridge (toner cartridge) and the lines should go away.
Jul 19, 2011 | HP LaserJet 5550 Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
49.2FCC ERORR
toner is faulty you have to change it..
Aug 20, 2009 | HP LaserJet 5550DN Printer
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
HP LaserJet 5550 Dumping Excess Toner...
Are you using HP toner?
Pull out the cartridges and vacuum out the printer. Get a compressor or canned air and blow the printer out. Vacuum again,
Install HP toner and try printing again.
Mar 12, 2009 | HP LaserJet 5500 Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
Help
1st page prints perfect but the 2nd page comes out with very light and skipped printing.
Oct 22, 2007 | HP DeskJet 5550 InkJet Printer
48 people viewed this question
jasbo
jasbo
