Question about GE GSH22KGM Side by Side Refrigerator
Where is the defrost timer on my side by side fridge GSH22KGMB BB
  • 195 Answers
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Posted on Dec 07, 2008
  • 111 Answers
SOURCE: GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Posted on Dec 16, 2008
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
Posted on May 28, 2009
  • 159 Answers
SOURCE: Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Posted on Jun 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: fridge less and less cold. both sides. now totally
The parts manual on that refrigerator show a defrost timer inside the fresh food compartment behind the control panel. Need you to turn the timer clockwise with a flathead screwdriver slowly until the compressor stops. Leave it alone for 30 minutes and if it does not turn itself back on then we need to replace the timer. If not we need to unplug the refrigerator and remove the back panel inside the freezer. We will need to test the defrost heater and inspect the defrost thermostat. Let me know when you are ready. The part number for the timer is 68233-3
Item number 13 top right hand side of photo.
1acbff1.gif Let me know if I can help, Thanks Sea Breeze
SITE-> http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
Need to know where the defrost timer is located on a GE SIDE BY SIDE MODEL GSH25JFRF-BB. its a 2001 model if that matters.
hello , hope this helps
your model shows that your model has a main board . the defrost timer is now a main board and everything runs through that board. behind the ref . square cut out by the btm with 6-8 screws that hold the cover in place.
Oct 10, 2014 | Refrigerators
Have a be side by side model GSH25JFRF-BB the freezer won't go into defrost mode I know you can manually make it by using a flat screwdriver and turning the little plastic thing on a reg fridge but I
The "Little Plastic Thing" you're referring to is a timer - usually found under the front bottom of the refrigerator. If the timer is stuck, your defrost cycles won't run. There are other reasons for refrigerators not defrosting, but the timer is the most frequent cause.
Works fine than shuts off completely after 2 or 3 weeks
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
bb
Sep 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
GSS201ETA BB Right Side is not cooling ( Freezer on left is fine, have removed all shelving and ice tray ) No cold air is flowing to the right side ! What do you suggest to troubleshoot ? Thanks in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 07, 2010 | GE GSS20IEP Side by Side Refrigerator
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
heatman101
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No power & not running
Hi, you have to check few things, first of all check power at the outlet for 120 volts. If the light in the fridge works, the defrost timer, cold control and possibly the wiring are the most common things that can make a fridge sit there and be dead, not working.
The defrost timer might be stuck in defrost, turn the timer screw to advance the timer and if the fridge comes back on, replace the defrost timer. You can join the wires together to by-pass the cold control for a test, if the fridge comes on, replace the cold control...
Take care
May 02, 2010 | LG LSC26905TT Side by Side Refrigerator
I have replaced motherboard and defrost still is not coming on.
Your defrost timer may be completely out. We have parts if you trust us! We are HONEST! Hope this helps. Ella
Aug 18, 2009 | Refrigerators
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer works fridge does not on a GE GSS22QGMC BB
you need to take freezer evaperator cover off , then turn it to defrost and test the supply voltage across the defrost element. if no volts then test the round disk looking thing with 2 wirers comming out of it . with the supply power removed from the power point, the coil frozen up , disconnect these wirers and use a continuity checker such as a multy meter on diode check or buzzer mode, you should have a closed circuit through the defrost termination thermostat (round disk with 2 wirers) , it is in series with the defrost element thus cutting the power to the element if the coil temp gets too high and terminates the element , the timer will time out after it's time duration is reached. A good way to test the motor in the timer is to put a texta mark on the dial of the timer and check it in 1/2 hr, to see if it has moved.AFTER YOU HAVE PUT THE ELECTRICAL CONNECTIONS BACK AFTER TESTING THE TERMINATIN THERMOSTAT AND MADE IT SAFE, YOU WOULD PLUG IT BACK IN.
The defrost timer needs to be connected to power of the fridge to opperate.
regards
****. let me know your progress pls.
Mar 31, 2009 | GE Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
