Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
My black and decker grasshog keeps feeding line out and raps around the motor
  • 313 Answers
SOURCE: black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Posted on Jun 19, 2008
  • 313 Answers
SOURCE: black and decker grasshog trimmer line feed problem
email publication@bdk.com or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Posted on Jul 28, 2008
  • 64 Answers
SOURCE: Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Posted on Aug 07, 2009
woobie dog
  • 1273 Answers
SOURCE: how to reload the line on a black and decker grasshog xp
Hello, W/D here. This is a previous post, but it should help.
I'm afraid that mental pictures are the best I can do, but bear with me; I'm good at it....We'll go over the spool parts, and the first time you wind tha spool, don't put any line on it....just read the directions while you hold the spool in your hands. Get a feel for what you are going to do. See how it will fit where it needs to go.....
All right......
Pull the spool out of the head.
Just look at it. You'll see that it is actually two spools.
Look at the divider between the spools. See the notch?
Look at the middle of the spools, or the core, where the line winds on the spool. See the small holes, one for each spool?
Flip the spools upside down. Look at the bottom. Note the notches in the rim of the bottom, and the arrows indicating the direction to wind the line. Look near the notches. There should be numbers next to the notches. This is the line size that fits your machine.
Take a brief look into the hole where the spool will attach to the head. We'll talk about that in a minute.
All right, let's do it. Remember, no line for the first walk thru. Take your line and snip the end at an angle, say about 45 degrees. Now take the pointed end and poke it about 1/8" into the small hole in the core of the inner spool (the spool closest to the bottom of the spool assembly). The purpose of placing the line in the hole is to anchor the line while you wrap (load) the spool. Start wrapping the line on the spool, going in the direction of the arrows. When you have that spool wrapped almost to the diameter of the rim, place the line in the bottom rim notch that is 180 degrees from the notch that is in between the spools. The line should fit into the notch snugly. You want about 6" of line to hang out past the notch and cut it so you have a 6" tail hanging out.
Now, fill the outer spool the same way. When you get it full, you'll pass that line into the notch in between the spools, and anchor it into the notch on the rim. Again, leave about a 6" tail, and cut it off.
Hard part's done. Get the spool close to the head, and thread the tails into the grommets on the machine head. Once both ends are in the grommets, straighten up the spool (align the notches holding the tails with the grommets) and push the spool into the head.
Almost there! When the spool is firmly set in the head, you'll feel a bit of a click, Grasp the tails, and tug on them enough to pull them out of the notches that were anchoring them to the rim.
Let's check our work. Push the spool in, simulating bumping the spool on the ground to advance the line. Once you have pushed it in, tug again on the tails. You should pull about an inch or so from each side, and then the line will stop.
Once you have that, you're done!
Now, about the hole in the bottom of the spool where it connects to the trimmer head....Sometimes, the line will be difficult to advance, so you should clean it out a bit from time-to-time. The trick that will help you is that, after cleaning it, put a little graphite dust in the hole. This lubricates the advancing mechanism without leaving an oily residue that will collect debris. Don't do it this time, maybe not next time, just some time. I probably do this maybe every eighth or tenth time I wind the spools or so. I buy the graphite usually at Lowe's2.gif or similar. It's used for locks, but you an also get it at Hobby Lobby where it's used for Cub Scout race cars (Pinewood Derby). Same stuff.
Sorry about no pictures. Turns out you didn't need them after all!
You've been a great student, and it's been a pleasure.
Best regards, --W/D--
Posted on Aug 19, 2009
  • 30 Answers
SOURCE: Line ffeds to fast on grasshog gh600 model
I have GH700 model with the same problem. I changed the line from a smooth round .065" to a star-shaped .065" (Rino-Tuff from Home Depot online) solved the problem. The manual advice was bunk. Shaped lines have fixed this problem with other electric trimmers, and I've been told that Walmart carries one.
Posted on Sep 13, 2009
Black decker troubleshooting
TRY REWINDING THE REEL THE OPPOSITE DIRECTION
Aug 03, 2014 | Black and Decker USA BLACK&DECKER GH710...
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
How to I feed the line in my Black and Decker battery GrassHog weed eater
There are 2 models one has a extendable handle these are both Grasshogs, if i was told incorrectly please contact me. Thank you
12" 18V Cordless Trimmer and Edger MODEL # NST2118 Page 10 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90559891,NST2118.pdf
18V Cordless Trimmer and Edger MODEL # NST2018 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90509965,NST2018.pdf
Jul 09, 2011 | Black & Decker Garden
Battery to fit Black & Decker CST20000 Grasshog weed eater. Where can I buy just the battery or battery pack?
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
May 20, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Dec 14, 2009 | Black & Decker 14" Grass Hog Xp...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black and decker grasshog
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
377 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
