Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi ss30 (ry30544) pull string keeps jamming
It's taken apart corrected and jams again after several pulls.
  • dandeb1999 Jun 26, 2008
    The pull cord came off of the spool and jammed. I can't figure out how to take the housing off to respool the line. Any ideas? It seems like the clutch has to come off before the housing is removed but there are no screws I can find. Any ideas?
  • Anonymous Oct 14, 2008
    taken it apart to fix string & forgot how it goes back together.
How to put new line on spool
Posted on Jun 15, 2011
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
Posted on Jun 01, 2008
  • John Helmuth Johnstone Jun 12, 2011
    Yes...this must be my problem..I have take it apart and repaired the cord..4 times...I am going to buy a new housing with all the gutts....... 23.00 + shipping...
How do you unscrew the clutch plates?
Posted on Jul 17, 2010
    I have a RY30544 with the same issue...take it apart..fix the string...without the plug..pull and recoils just fine..but in a Spark plug...cord jams on 2nd pull.... I clutch comes of by unscrewing it CCW with a small pipe wrench..but you have to put a Piston Stop into the Spark plug hole or use a nylon cord...something to stop the piston from turning. I have a stop that fit in the SP hole.
Remove the clutch by using a T-25 torx driver. The clutch housing will then come off. Then you have to unscrew the two clutch plates and the housing will come off.
I'm just experienced the same problem, although in my case, the shaft seems to have overheated causing binding which prevents the recoil. I need a new housing. Does anyone know if part are available?
Posted on Jun 29, 2008
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
The pull start cable is jammed on our Ryobi brush cutter mocelRBC-320E how can we fix it. Thankl you
Going to have to pull it apart down to the cable and see what is jamming it but be careful cause the coil spring in the may come out usuall just been pulled to hard and stuck
Jan 24, 2011 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
My Ryobia SS30 SS# ATJ0830439,weed eater, the pull cord will not retract please help Thank You Gail
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Apr 28, 2010 | Ryobi Garden
The pull string coil came loose cant figure out how to get the piece that connects to the shaft off on the ryobi ss30 weedeater
There is a cover that you loosen you pull back the handle then youll see a clamp I think its 5/16 loosen it will move but there is a thottle cable you have to loose off the thottle on thr carberator then it will slide off ,if it is a clutch ,the clutch has to be removed by the way of the the arrow then you can get to the rewind
Nov 04, 2009 | Ryobi Garden
How do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
May 14, 2009 | Garden
Ryobi SS30 Problem, please help
Hello:
Are you Sire you Used the Correct Fuel Mix Ratio?
Remove the Muffler and Look Into the Exhaust Port.
Is the Piston Scratched and Gouged or is it Smooth like Glass?
If Smooth like Glass, then Check the Carburetor for Trash.
If Scratched and Gouged, then the Wrong Mixture was Used and the Engine is Trashed and will Require a New Piston and Jug (Cylinder) Assembly (a new unit will be cheaper than the parts to repair this unit) for the Unit to Run again.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Ryobi 15" Electric Factory Reconditioned...
Screw cap to reel head of ryobi ss30 weed eater will not come off
The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
Apr 05, 2009 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,223 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
