Question about Olevia Televison & Video
We have a pink screen. we have gotten it to a b and white screen . we went into video color, brightness and it goes all the way to 255 on its own. at contrast it goes into japanease. we vhave tried to adjust everything but it holds for a minute and then goes back to the 255 settings. we have a message when on blank screen that says 'v-chip locked'. can you help? olevia LT32HVP
  • costine_repo Oct 01, 2010
    At present it has dark screen that turns into a white screen with thin multi colored lines horizontally. A few mintes later it changes to a multicolored bluescreen with lines veticalkly chanig pattern continously. We cannot change channel or go to menu anymore. It won't even turn off without being unplugged. I don't see much hope but maybe i am wrong. Thanks
    President:
  • 2,777 Answers
So the whole screen is discolored, even when you go into menus? Is this on all inputs? If so that is a very bad sign for the TV.. it indicates some major hardware failure. Let me know the answer to the first couple questions and we will go from there.
Thanks
Tim
Posted on Sep 27, 2010
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    This is definitely major hardware failure. Most likely the video board inside the TV has completely failed... It is very expensive to repair unfortunately :(. If you think it may
    still be under warranty please contact the manufacturer to file an
    RMA. If you happened to purchase the TV with a major credit card (not
    a debit card) there is a good chance it may still be under the free
    extended warranty most credit cards place on electronics. Please
    contact your credit card company to inquire if they do this, and they
    will be able to file the claim and get you a refund for the TV.
    That would be my recommendation, otherwise you may just end up replacing this TV, so sorry about the bad news :(
    Tim
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The picture on my DVD player is pink! I have tried 3 different DVD players and they are all the same. I have tried adjusting the colour/contrast/brightness etc and nothing is working. The picture is either...
Hi,Would you pls check the connection that you have made between TV and DVD player..?
2xRCA (white+Red) will go to Audio IN sockets of TV in addition to 1xRCA Yellow video cable goes to "Video IN socket of TV..
if the connections are right than you must select the right source on TV ,as AV1 ,AV2 which corresponds to the cable input sockets of your TV.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 11, 2011 | Televison & Video
White color in LCD monitor appears as pink anywhere ! but sometimes it back to white color truely.
This can be a common problem with laptop screen when white goes pink. This is caused by a faulty cable that runs from the laptop motherboard to the inverter just under the screen.
The cable becomes stretched after a while by movement of the laptop lid which pulls a pin from the cable.
What i suggest you do is take the laptop to PC repair store and have them fit a new video cable or order a replacement video cable from eBay and replace the cable yourself.
Don't be fooled by the preconception that its a bad CCFL bulb (backlight) as this is not the case.
Regards
Jun 25, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Princeton 19" went from bright white to dull white
david78910, First disconnect and reconnect the monitors VGA plug from pc vga port a few times to make sure of good connection at the port. Report back here with results! If that doesn't fix your "pink screen" symptom, then possible bad inverter supply inside unit or the CCFL tubes may have lots and lots of "on" hours use on them and need to be replaced. Yes, you could also have bad (almost dead) switch-mode-power-supply inside unit if "known-good" monitor works perfectly with your pc. 12fixlouie
May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Pink line down screen
I have a laptop that has been doing exactly the same. It started off with a fine pink line. After almost a year it now has gotten wider and has white lines and all other colours. It could work like that for quite a long period. It is a conection in the bottom of the screen but is so delicate... Only way to REALLY fix it is to have the screen replaced which could be quite an expensive thing to do
Jul 06, 2009 | Sony VAIO VGN-FS640W Notebook
White colors come out pink and the wth bal is auto
I replied your question about pink tint noise in picture.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Brightness
there is two transistors in brightness section near eht so you can check all small transistors around eht
Jun 24, 2008 | TTX Advantage Series -1770 (White) 17...
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Booting but goes black
Take the reinstallation CD and boot from it. Then click R and It will ask what drive you wish to enter. hit the drive number you wish to enter. It will give you options. Once your in type fixboot. just as I have it and it will ask you if you wish to rewrite the boot sector. Hit Y and press enter. Then type exit and it will reboot. If that dosent work you will need to do a repair install. I will walk you through that if we need to.
May 27, 2008 | Dell Dimension 4600 PC Desktop
Televison & Video Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
