Question about X2Gen MG19MY 19" LCD Monitor
If i am on the phone when the monitor is running I get a loud bizz on the phone, this only happens when the monitor is on.
    Novelist:
  • 112 Answers
This may not be an absolute fix but your monitor is connected to the PC, so you may be getting some type of feed from the PC through the graphics part of the system which only becomes prevalent when the circuit of the graphics signal is completed with the monitor on.
Is you system grounded?
How about your system not being shut off for long time. Are you the type to just leave it on and just log off instead of turning off?
Try turning off both the PC & the monitor, and unplugging them for about 10 minutes, While they are unplugged, push the power switches on/off a couple of times to discharge any kind of residual charge in the capacitors. I know with my tower PC if I unplug it then later hit the power switch, the red power & green hard drive light would come on for a split second.
DRAIN any kind of charge in them and be sure they are grounded good to each other as well as the buildings ground.
Posted on Sep 27, 2010
My ViewSonic 2230wm made a loud noise as it flicked once and shut off forever.
Getting the parts needed and repairing this monitor would probably not be cost effective. If nothing happens when you try to turn it on (i.e. no lights or LEDs come on) then it probably is the power suppley circuitry that is failing. If you are technically capable, you could remove the covers and look for a blown capacitor (the loud bang sounds like a capacitor).
Feb 12, 2014 | ViewSonic Computers & Internet
My compaq fs7600 monitor wont turn on
Hook a spare monitor to the computer, if no change! the Video Graphics Card is suspect usually built into the motherboard. But if spare shows picture, the problem lies in the HP monitor, as a last resort change the video cord from the computer to the monitor "if possible" to rule out something simple.
Mar 15, 2012 | HP Compaq FS7600 17" CRT Monitor
My desktop s running but monitor goes black after a few seconds. tried another monitor but does the same thing. my computer did make a loud noise prior to this happening is it my power supply
It is likely your graphics card failing. If it is a plug-in type you can remove it and replace with another. However you may have an onboard video card as well as a plug in type, if so you could remove the plug-in card and that would automatically enable the onboard video. Look to see if you have two monitor ports on your computer to verify this. The onboard may have a blanking cap over it. Details in the picture.d0b59c4.jpg
Oct 07, 2010 | Computers & Internet
I am switching on my monitor. but it is blinking and the green light flashes. it is also making a bizz noise inside.
a common way to solve this is to put the BIOS into its defaults...
i.e, loading the BIOS with default settings..
to do this you need to open the case of your CPU then, on the motherboard there is a small button sized battery, called CMOS battery...
take it out and after a minute or so put it back...
in this one minute, the BIOS will get reset to its default settings...
also check whether the RAM is fit in its slot. (remove and then insert RAM)
you should now be able to work........
If this sol. helps please give a vote....
Sep 17, 2010 | AOC 1556NB 15"
My Dell is making a loud sound when printing. What could it be?
you need to clean inside parts and check the toner cartridges like pcr opc drum mr
Dec 14, 2009 | Dell 1720dn Laser Printer
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Pop - bang noise then went dead after a period of time
You've blown a capacitor and probably the horizontal output circuity. It's time to get a new LCD monitor.
May 30, 2009 | Sony GDM F520 21" CRT Monitor
FURNACE RUNNING LOUD
sounds like either the motor is off balance
or is going bad again
either way id be on the phone to the guy who did the rapair
more than likely the set screw on the sqiral cage came loose and now its vibrating
Nov 11, 2008 | Aprilaire 700 Humidifier
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
GE cordless phone 2.4 ghz
Your phone must be away from other appliances (i.e. microwaves, radios) and computer equipment (i.e. wireless routers, monitors). The phone runs on 2.4GHz which often conflicts with them.
Mar 15, 2007 | GE 21009GE3 for 21028GE3, 21028GE3,...
X2Gen MG19MY 19" LCD Monitor Logo
205 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
