Question about Canon PC150 Personal Copier (PC 150, PC-150) Printer
I have a Canon PC 150. It squeaks when copying. How can I fix this.
2 Suggested Answers
CosmaP
  • 409 Answers
SOURCE: Paper Jamming
See if canon sell a Roller PM kit and replace the rollers.  you could try cleaning them with a lint free cloth and some fresh water.
Posted on May 28, 2009
2007 Qlink Achilles 150 scooter free service manual
Brake squeaking may be caused by glazing. You can freshen the surfaces with fine sand paper. Depending on the cost and your dexterity, perhaps they are simply worn enough to merit freshening with new parts.
Jul 29, 2014 | 2007 Qlink Achilles 150
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Canon Imageclass D661 printer is making a squeeky noise when printing. Sounds like whatever is turning is squeaking. Any suggestions?
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
Aug 25, 2011 | Canon imageCLASS D661 Digital Printer
A loud squeak
hello,
-the canon laser shot LBP-5200 printer is making squeaking noise most likely the printer needs cleaning or oiling as well, if you are not familiar w/ the cleaning or oiling it up, you can bring it to a local repair center, if it is still in warranty w/ canon you can call them up and have them fixed that printer for you.
link for cannon support page: "http://www.usa.canon.com/cusa/office?pageKeyCode=contactUsLanding"
Feb 25, 2011 | Canon LASER SHOT LBP-5200 Printer
Whenever copies are made, or a fax comes in, the machine squeaks very loudly. How can I fix this?
can you say from where the sound comes? If from left side check the drum unit and fixing unit. If from back check if all plates or main motor, or fan are ok.
If from paper tray check for any breakage, paper leftovers,...
Hope that helped
May 13, 2010 | Canon imageCLASS MF6590 Copier
Paper Jamming
May 28, 2009 | Canon PC-921 Black and White Copier
Darker copies
GO ON LINE AND TYPE THE FOLLOWING INFORMATION.
CANON PC-150 GRAYSCALE COPIER SERVICE MANUAL AND DRIVERS
OR
CANON PC150 COPIER DRIVERS SERVICE GUIDE
CANONUSA.COM
IF A USERS GROUP FOR CANON FORUM
TRY TYPEING THE FOLLOWING:
CANON PRINTER USERS GROUP FORUM
ENTER
PICK FROM THE BEST OF WHAT YOU NEED IF ANYTHING.
ROD
Feb 09, 2009 | Canon PC-150 Grayscale Copier
Squeaking
the squeak is coming from the drum unit. If you take out the drum and rotate it by hand it will most likely give you the same noise. you may be able to stop it by pouring some toner on it, but in reality it is more annoying than a problem.
there is a blade that scrapes off excess toner from the drum, it is slightly dry and causes the squeaking, technicians usually use a special powder that looks like baby powder to "lubricate" the blade, and stop the noise.
Aug 11, 2008 | Canon PC1061 Copier
Cannon pixma mp750 - it is telling me "waste ink near full" but i can't find any mention of it in the guide etc. It is not printing at all. Can you help?
Just another little way that Canon have found to get more money from you, would probably cost you at least $150 for Canon to fix, but you can, I think this should work.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jul 05, 2008 | Canon Office Equipment & Supplies
Canon PC150 Personal Copier (PC 150, PC-150) Printer Logo
29 people viewed this question
old marine
old marine
