Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
When I plug in my Porter Cable job boss compressor it barely turns over and usually blows the breaker. Any thoughts?
    Scholar:
  • 146 Answers
If this happens with no pressure in the tank then you may have a bad start capacitor on the motor.
If this only happens after the tank is full of air then you need to make sure the check valve is working and releasing the head pressure from the lines.
Posted on Sep 28, 2010
Why can't i get over 35 lbs on my job boss air compressor?
Check for internal leaks in compressor - compression rings on the cylinder braking often.
Another problem would be fittings or piping leak - usually a simple O-ring replacement will do a job.
May 13, 2014 | Porter Cable 4 5 Gallons 150PSI Job Boss...
How to turn on porter cable compressor
Check for power - often it is a pressure switch need to be replace.
Or even better to replace with Digital Controller.
Check this site: www.CompressorController.com
Oct 09, 2013 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Porter cable compressor electrical smell won't run
wow
Check motor and pressure switch for erosion, electrical strikes in plastic
Replace if bad
Dec 31, 2012 | Porter Cable Cable 4.5 Gallons 150PSI Job...
My Porter Cable Job Boss compressor won't shut off. It builds up pressure but just continually runs.
Pressure switch - replace as soon as possible
Overpressure would be possible in that tank - it is dangerous !
Oct 20, 2012 | Porter Cable 4 5 Gallons 150PSI Job Boss...
UNLODER DOESNT RELEASE BOGS DOWN BLOWS FUSE
the non return valve to the tank is certainly the next thing to look at .
Jun 06, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Job boss compressor wont run
have you checked the motor reset
will be on the motor
May 10, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Does not auto turn off
Sounds like the pressure switch is shorted together. Unwire the switch and see if it shuts off.
Apr 08, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
My c3151, loads to tank fine then the unit will cut in and out. The unit will trip a breaker. Is this an easy fix?
the line from the compressor to the tank should have a check valve .so that the compressor head does not have pressure for easy start up... check and replace if needed. when compressor attempts to start its to dificult with the pressure, causing circuit overload.
Jan 12, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
My porter cable pancake compressor keeps blowing the circut breaker. This is a new problem and it still does it on a 20 amp circut. Help...Thanks
hi!
there are several factors we can consider it comes from short circuited.if you did not rewire the circuit its fine,but if you rewire the circuit and it happen there is wrong connection it may happen every time you power on,check your connection the common line of the motor should as your L1(line 1) and line2 should connect to line capacitor w/c that is your starting capacitor.the pressure switch should be in series connection with line 1 or on line 2
check also the bearing of your motor if worn out replace bearing,because the worn out bearing develop hi ampere it shorted also the electrical system if there is sticky bearing.check also your capacitor if busted capacitor it will also open your breaker besause it can not start up.hope this can help you.
Aug 09, 2009 | Porter Cable C2150 2 Hp 4 Gallon "Job...
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
222 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
