Question about Mantis Garden
7222m mantis tiller need a diagram or set up adjustment for the carburator
    Scholar:
  • 150 Answers
Set low speed jet 1 turn out high speed 1 and a quarter turn out
Posted on Sep 27, 2010
I need a mantis tiller primer bulb or one that will replace it
just got one at Lowes Hardware. Its a three pack with three different sizes. largest works
Jul 27, 2012 | Mantis Tiller
Won't start
Remove carburator also remove diaphragms and gaskets, soak carburator in carb cleaner over night, then spray dry. put back together with new diaphragms and gaskets. Triky part is next H-red ( high) L-white (Low) adjusting screws remore plastic caps to allow u further adjusting. This will get your tiller back up and running, let me know if it helps or any questions you might have
Apr 22, 2011 | Mantis 2-Cycle Tiller
MANTIS TILLER DOES NOT RUN SMOOTH AT HIGH RPM.
Check to make sure it is getting good spark from coil. Make sure proper plug and plug gap is installed. Check for fuel flow to carb and make sure carb is adjusted properly.
Jul 08, 2009 | Mantis 2-Cycle Tiller
Mantis tiller won't run at high rpm
check the carburator, it sounds like a main jet is clogged or the carburator is dirty. Is the air filter clogged? Is the motor under strain?
Jul 03, 2009 | Mantis 2-Cycle Tiller
Runs only with the choke more than halfway closed
adjust the carburator, it is running to lean.
Jun 17, 2009 | Mantis 2-Cycle Tiller
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
May 15, 2009 | Mantis Tiller
Garden Logo
954 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
