Question about Dryers
My sears dryer will shot off when iy gets hot,going through its cycle. If i let it cool down for about 10 mins. I can restart and continue for another 20 mins before it shuts down again
  • Dryers Master
  • 3,361 Answers
Take the exhaust vent off the rear and try it.
If it runs OK,repair the vent blockage/restriction.
If it does not run OK,replace the motor.
Posted on Sep 27, 2010
Dryer not completing a full cycle. shut off after 10 min and has to cool down before restarting again.
I dont know but I'm having same problem. I think it is in the timer. Must do more research. Didn't find answer here!
Mar 06, 2011 | GE DVL223EBWW Electric Dryer
I have a Kenmore 80 Series Gas Dryer. We replaced the motor and blower wheel in October of 2010. Recently the the dryer has been stopping while drying clothes. No matter what cycle I put it on, it almost...
Hi, In looking at your problem please do the following. Go behind the dryer. The vent hose that is attached to the back of the dryer has to go straight to the wall outlet. It must not have any bends whatsoever. Its a straight shot to the wall. This should take care of it shutting off and being too hot. You may need, after the above, to change out the cycling thermo. Thanks for your inquiry and hope this helps. Have a Good Day!
Jan 18, 2011 | Dryers
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a kennmore electric dryer all of a sudden it will only run about 10 minutes and shuts off when you try to restart it won't come back on you have to wait for a little while then it works but only for...
Sounds like it is getting too hot and the hi-temp safety switch opens up until it cools down again. Try vacuuming all of the vent pipes and hose. Remove the lint screen and wash it in hot water and detergent to clean it of fabric softener deposits. Hope this helps!
Feb 09, 2010 | Kenmore 63942 Dryer
Dryer runs for 5 or 10 min then shuts off
You cycling thermostat is bad, making it run on the thermal cut off. When it gets to hot, it breaks the circuit. After it cools, it remakes therefore you are able to turn it on again. If you continue to operate it this way, it will go out therefore putting you thermal fuse out also. Go to partselect.com. enter your model number. This will bring you unit up. You will be able to find the parts you need and even order them if you want. As of now, all you will need is a Cycling thermostat
Oct 09, 2009 | Kenmore Dryers
Sears Kenmore 08980800 Stops after 10 minutes of operation.
Sounds like the motor may be getting hot and kicking out on the motor overload switch. When it cools down it will reset.
Jun 10, 2009 | Dryers
My electric dryer will start and just shut off after about 10 min
sounds as if hte motor is overheating, whe nit cools down for a while it restarts, gonna need a new motor eventually
Nov 30, 2008 | Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
