Question about Canon PIXMA® MP460 All-In-One InkJet Printer
My printer canon MP460 says there is a paper jam but i can't see any paper there,can you give me any suggestions?please,thank you
SOURCE: canon pixma mp460
hi, did you have a solution for the above problem as i have the same?
email is copipwllheli@aol.com
thanks
Posted on Dec 29, 2007
SOURCE: mp460 canon all in one
Same problem .Alarm light on and paper jam advice on the screen. No paper there...
Posted on Apr 19, 2008
SOURCE: canon mp180 paper jammed
I finally fixed the problem by running two sheets of heavy card stock through at the same time. With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor. I previously found that only one sheet at a time did't work.
I found this solution posted by JsamJr answering another question but it worked for me. pushing the card in and then removing it and pressing ok worked
Posted on Apr 28, 2008
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
pineworks
  • 4041 Answers
SOURCE: Paper Jams
Hello there
You may not see a paper jam, or some bits of some thing stoping it.
Posted on May 01, 2010
After clearing a paper jam on my MP460, I get another error message, 'the paper is jammed. Clear the paper and press [ok]', which can't be removed. Pressing [ok] has no effect and I can't get into the main...
A few possible solutions:
- Open the top of the printer and look along the print path for pieces of paper.
- Press the reset button.
- Turn off the printer first and then unplug it. Plug it back in and turn it on. Wait for it to start up.
Bot
Apr 12, 2010 | Canon PIXMA MP460 All-In-One InkJet...
The paper consistently jams in my Canon MP460
-check the paper feed guide rollers, clean with a cotton swab
Sep 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper iam
open the printer back cover and remove paper from it
May 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 Paper Jam
this is only a possible solution.make sure the paper is between 17  to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam in a mp460 printer(canon)
clean up the roller that picks the paper up.
Jan 30, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp460
check for obstruction and paper thickness lever on the printer and try printing again.
Apr 14, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Mp460 canon all in one
Apr 08, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460
thanks
Dec 11, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA® MP460 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
