Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Starts fine and dies in minutes. Is getting worse. Have cleaned carb, checked linkage and switch for shutdown. Fresh gas. Fuel runs freely to carb.
  • Tecumseh Master
  • 7,482 Answers
Check your fuel filter if you have one.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
1988 aric cat 440 jag when primed will start and run then dies
Sounds like there is water in your fuel. If there is, you can see it in the bottom of the tank or just drain it and put fresh new gas in it. If straight fuel is left in small engines in the off seasons, they will gum up the carb with varnish and the carb will need to be removed, cleaned, and reinstalled.
Sep 21, 2014 | Garden
2000 Buell Blast runs great around town. Freeway speeds runs for 3 to 5 miles then out of nowhere dies. Acts like it's running out of fuel then dies. I have pulled the carb and cleaned the jets. C
If it starts up after sitting for a few minutes, (like 2 or 3) it could have a plugged fuel filter or the gas tank strainer built into the fuel valve could be plugged too. Drain the gastank anyway and change the gas with fresh. can't hurt. If it takes 15-30 minutes or after the bike cools some I would look at an ignition coil. Check to see if it has spark next time it quits.
Jul 05, 2012 | 2000 Buell Blast
I have a 2001 Suzuki Maurader 250 - we bought it used and cannot get it to start - we have had it running but the next day it will not start. |We have changed the oil, plugs, cleaned the carb and now it...
Drain the carb with the gas valve on the tank turned off. Now turn the valve back on and see if gas again begins to flow out of the float bowl. If no gas drains with the valve open then remove the fuel line at the carb and check to see that fuel flows freely through the fuel line. If gas flows freely out of the fuel line then the float needle is stuck closed or trash is plugging up the needle jet assembly. If so, remove the float bowl and free up the needle. Use spray carb cleaner and the little "straw" that comes with the can to direct the spray into the float needle fitting. Fuel should flow when the float is down and stop flowing when the float is lifted. Pull a spark plug and ground the metal against the cylinder. Check for spark. If there is no spark then check the operation of the kill switch on the side stand and the handlebar. Use a multimeter to check the switches. Get fresh gas and install an in-line fuel filter to keep any trash out of the carb. Clean the air filter. Please rate my answer. Thanks.
Apr 03, 2011 | 2001 Suzuki GZ 250 Marauder
2001 yamaha breeze wont stay running
i had the same issue. it's gonna be a blockage in one of the vent tubes to the carb. check the line to the left of the carb that runs next to the gas tank. if thats fine then check the gas cap line. then if thats all good then check the line that runs below the carb. these are all vent tubes and allow the carb. to refill with fuel
May 19, 2010 | 2001 Yamaha DT 125 R
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Dec 18, 2008 | Honda Chipper Blower and Vac: 5.5 Hp Gas
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
233 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
