Question about GE JVM1440 Microwave Oven
Microwave just didn't work one day. Timer and clock do not work either. It's as if it is not plugged in and it is. Have already checked the outlet
  • GE Master
  • 8,404 Answers
There is a fuse on the inside floor of the cabinet near where the cord enters ... Remove the cover ... find the fuse ... replace it with exactly the same size and type.
Thanks for your interest in FixYa.com
Posted on Sep 27, 2010
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
Microwave stops randomly on its own, dispaly flickers and I get prompted to enter clock settings, what should I do to fix it
When a microwave asks for the clock settings, it has lost power. Check the plug and the outlet for damage or if it is loose. When on, vibrations can cause the plug to reposition if loose enough. Even a very short loss of power will reset the microwave. If the plug/outlet is ok, then check to make sure that the fuse for the outlet is tightened fully (breaker switches do not have this problem). Last, try another outlet as the wiring to the outlet may be loose.
Feb 11, 2012 | Danby DMW773 Microwave Oven
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
MYS SAMSUNG MICROWAVE'S TURNTABLE HAS STOPPED WORKING. IT WAS INTERMITTENT FOR A FEW DAYS. THIS HAPPENED WHEN MY WIFE TRIED TO BOIL EGGS IN MICROWAVE AND THEY SPURTED.
Possible that the temperature cut off sensor has switched off. check on the panel side after opening the top cover and see the continutiy . check the inside of oven and clean well the fitting area of the magnetron. Check if fuse is blown.
It is possible that the magnetron was working dry and burnt out.
So if all the other sections are fine and the relays ae clicking then it should work. If not clean the door latch switch.
Remove the plug from the outlet and let the microwave reset. the controller/timer can then be set back with the clock.
Hope this works.
Aug 27, 2010 | Samsung Microwave Ovens
EVERY PART OF THE MICROWAVE STOPPED WORKING
There is an internal fuse inside. Need to find the cause for it blowing or it will just go again. Check the monitor switch and door switches. Eric
Aug 08, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Our oven does not come on at all.
Hi, the door micro switch not working ,also the fuse need to check if it is fine check power outlet and breaker recock it.
Jan 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
21 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
