Question about Ricoh Aficio 450 Copier
Ricoh 350 says doors/cover open - Ricoh Aficio 450 Copier
  • 29 Answers
You can check the front door switches and the fuser switches, if the problem continuos maybe the laser unit has a problem, because the energy supply cross by swtches and the laser unit before closet the circuit. or you can check the 24 volts circuit has a problem.
Posted on Dec 01, 2010
I have a ricoh aficio 2035 and there is error code sc 350, what can i do ?
open the right door and you will see a black sensor above the drum unit.
remove the drum unit and clean the sensor in the machine at that position .
rfix the drum unit and power the machine .
please do this carefully as you may damage the drum .
good luck.
May 05, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Ricoh MP1800L door open always.please help
ensure cover has pushed or not, to door sensor switch
Dec 30, 2013 | Ricoh Aficio Office Equipment & Supplies
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Flase door open reading on my aficio 350. The door is shut. The machine is showing that the door is open but it not. It close as it should be.
when the door closed it actually activates the switch. see on the door if any plastic piece from the frame is broken or not and locate where in the machine does the front cover activates switch. it will be easy to find the broken part.
Sep 23, 2010 | Ricoh Aficio MP 161 Black and White Copier
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
How to solve error SC471 on my Ricoh 3800C
That is a transfer belt lift up error. The transfer belt lifts up for color and goes down for black only prints. Open right side door and check for paper stuck in the area near black rubber roller. Sometimes the belt dosen;t lift correctly. Open front door and turn knob on upper left counterclock wise to lower black transfer roller. On brown cover remove the top left screw and bottom right one (need to look on bottom side of cover) Slilde transfer unit out then back in. It is also possible the sensor inside machine is dirty.
Aug 18, 2009 | Ricoh Office Equipment & Supplies
Door/covers open
dear sir; check it out on the side door left hand side (if you face door) have piece plastic door switch actuator isn't broken, change door !
Dec 26, 2008 | Ricoh Aficio 450 Copier
The copier is a Ricoh Afcio 350
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Apr 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
87 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
