Kodak ESP7 PP All-In-One Printer Logo
Posted on Sep 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blank pages; new ink - Kodak ESP7 PP All-In-One Printer
Anonymous
Level 3:
  • Master 823 Answers
  • Posted on Sep 27, 2010
Anonymous
Master
Level 3:
Answers
823
Questions
0
Helped
239581
Points
2398
You need to change your print setting preferences to print on photo paper and choose the correct type before trying to print pictures. While in the picture you want to print on your pc screen, go to file and then print and choose preferences. Then change the paper type to the type of photo paper you are using (i.e. glossy, matte finish ect.) and hit "ok". Then trying printing your picture and see if this solves your problem.
1helpful
Hello . My Epson stylus c66 printer ,print but the paper is white.
Do you mean your Epson Printer Printing blank pages? The Epson printer printing blank pages due to wrong paper size, outdated printer driver, Empty ink cartridge, dirty print head, improperly installed ink cartridge, and more.
Follow the steps to fix the Epson printer printing blank page issue:
·Restart the printer
·Fill the empty ink cartridge and reinstall the new ink cartridge
·Update printer drivers. If you have done all the above steps but still the printer printing blank pages.
Then follow more steps to fix the Epson printer prints blank pages issue.
Hp lj cp1518 printer printing blank pages
you need new ink if not used it will dry up. if you are not sure go buy black ink
Mfc-j270w prints blank pages and cartridges are good, tried cleaning procedure several times
Did you try and copy something? or use another machine? Blank pages are usually the computer sending a job that contained no print information but not always-- tell me more.
good luck
Document is blank when print spooling and prints only blank pages. even test page printed is blank
I can only think its a problem with the ink cartridges.
Is it a new printer?
Have you taken the tabs off the ink cartridges?
Does it need a head clean?
1helpful
3answers
Blank page
printer not print test page properly. sheet is coming out sppdly
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
2answers
Dell printer printing blanks pages
? check that you did not leave the pull strip on the cartridge ?
3answers
Epson stylus c66 is new but in printing paper comes out blank
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
3helpful
2answers
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
