Question about Ricoh Office Equipment & Supplies
Ricoh 5000L Fax Installed new fuser and reset counters. Displays error 0-02 now.
  • 3 more comments
  • troyw856 Sep 27, 2010
    As listed in original post, the counters have already been reset. I need to clear the 0-02 service error code. Resetting the counter as you recommended does not fix this error code.
  • troyw856 Sep 28, 2010
    Have already tried turning machine in and off as well as unplugging the machine. How do you put the machine is SP mode before turning it off?
    Do you hold # while entering 107
    Q1
    Do you continue to press # while pressing start
    Q2
    How do you set PRINTER(01)
  • troyw856 Sep 29, 2010
    You need to enter SP mode (User Tools, hold #, enter 1-0-7, then press Start). Then set the PRINTER[01] bit. Turn machine off, then on again. This assumes the fuser/roller is properly operating and you just accidentally cleared the error bit state by replacing it out of sequence
    Q2
  • 944 Answers
Try to clear the service call condition switch the power off, wait 10 seconds, then switch back on.
or
just turn machine off while in sp mode using the red on/off switch This will clear the code
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 28, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 28, 2010
    "Clear/Stop", "1","0","7"' and "Color Start".
    Natarajan Ramasamy Sep 29, 2010
    q1)Yes is the answer.
    q2)cant understand be clear.
  • 2,272 Answers
Error 02-02H is a fuser error, and is either the heater lamp, fuse or thermistor, causing the "warm up error". This can only be reset by a needlessly over-complicated procedure in service mode once the trouble is fixed. Try this reset procedure as follows:--- To clear this error:--- Follow these steps
[User Tools] / [Key Op Tools] / [System Settings] / [#] / [Reset PM Counter] > select ADF Roller or Fusing Unit / [Reset] / [OK],.---------
in your case you select Fuser unit. ----------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 27, 2010
  • raj somaiya
    raj somaiya Sep 28, 2010
    This assumes the fuser/roller is properly operating and you just accidentally cleared the error bit state by replacing it out of sequence.
    Thanks for keeping updated with your query.
  • raj somaiya
    yes hold "#" and enter the numbers.
    Keep updated .thanks.
How do I clear 0541 error on a Ricoh Fax 5510NF.
Thermistor failure.
Thermistor in the fuser damaged or disconnected.
Mar 22, 2017 | Ricoh Office Equipment & Supplies
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Aug 24, 2009 | Office Equipment & Supplies
Purchased new fusing unit for ricoh cl3500n; installed; tried to reset computer by holding escape for 5 seconds; does not clear out error message 'replace fusing unit' ; nothing will print; can not get to...
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Jul 07, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
May 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Fax 3700L
Fuser error.....Either blown fuse, bad thermistor, or blown lamp. Problem needs to be repaired, and then a WAY over complicated reset procedure has to be performed in service mode to clear the error.
Apr 28, 2009 | Ricoh Office Equipment & Supplies
Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Jun 26, 2008 | Ricoh FAX5000L Plain Paper Laser
217 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
