I have a whirlpool heavy duty thin twin. Model# LTE5243DQ3. I cannot get the top of the washer off so i can access the lid switch The screws from the lid switch won't tighten, it is very loose and the machine wont advance beyond the wash cycle.
  • 3,051 Answers
Hi mary
Sorry we got disconnecteddo you have a e-mail address i can send the pict to
Posted on Sep 27, 2010
  • Michael Thomas
    Michael Thomas Sep 27, 2010
    Hey mary the transition plate that sits between the washer and dryer has 3 screws that need to be removed then the plate will lift up and outward towards you and flip up
    The timer is on the left side of the machine as you are looking at it
  • Washing Mach... Master
  • 3,361 Answers
Copy and paste the link for the Factory Thin Twin Manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
I have a electric whirlpool thin twin. It fills with water and agitates...then nothing. No drain, or spin.
check the lid switch,open the lid and on the right side you'll see a hole in the top panel,stick a screw driver in it,push down,you should hear a click,or close the lid and open it a couple of inches and close it,do this a few times,no clicking sound bad lid switch.
Sep 12, 2011 | Whirlpool LTE5243D Top Load Stacked...
It's heavy duty thin twin model. The cycle stops at spin and water stays in the mashine.
When it gets to the SPIN cycle,wait 45 seconds. If it does not spin,open then close the lid.
If it spins then,replace the timer.
If it does not spin,replace the lid switch.
Jul 27, 2010 | Whirlpool LTE6234D Top Load Stacked...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 90 heavy duty top load washer won't agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 06, 2010 | Kenmore 24032\24036 Top Load Washer
Whirpool twin washer & dryer lte5243dq3 drum off center
The ltw5243dq3 is a top loading washer with the dryer stacked on top. In order to remove things
1. One the angled piece of metal that is between the dryer and the washer there will be two screws. Remove them.
2. Next open the washer lid. There will be two screws on the right side. Remove those.
3. Close the lid. There are two final screws that hold the top part of the washer in place. You can't see them directly from the front so you might need a mirror or access to the back side of your unit.
4. Slide the top of the washer forward about 1 inch. List it up about 1inch and you will see that some wires are attached. Disconnect these wires so you can take the top off entirely.
5. To remove the front panel there are two screws. One on the left and one on the right. If you look down inside in the washer you will see them.
6. Slide the front panel upwards and then you will be able to remove it.
You should now be able to see inside your washer and it should look like the attached picture.
hope that helped,
mishkin
Mar 29, 2009 | Whirlpool ET8CHEXSQ Dryer
Lid switch
to replace lid switch unplug unit remove two screws for acess panel(runs at angle between washer and dryer)after removing acess panel you should see two 5/16 head screws holding the washer top down (at rear of top) take out these screws top should slide forward .unscrew the two phillps head screws holding switch to the top replace switch then work backwards to complete
Dec 26, 2008 | Washing Machines
Washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin Lid Switch and Return Pump access
where the washer and dryer attach just above washer lid there should be screws to rmove cover between units yours may have clips instead of screws that need to be removed to remove lid and top on rear edge of top there is a plug that hooks lid switch just watch when reinstalling top to be sure it reconnects..sorry for mix up those units had 2 different layouts over the years and without an image hard to tell which one you had
Jun 12, 2008 | Washing Machines
I have a Whirlpool Thin Twin model LT7000XTNO and the water will not drain after the wash or rinse cycles. I have tried it in each of the different settings (normal, permanent press etc.) Could it be the...
on most of those remove 2 screws in cover under console /timer on back edge of top will be 2 screws remove screws slide top forward switch connection is on front edge to acess pump 2 screws 1 on each side just below top on in side of panel remove and lift panel up
Jun 10, 2008 | Whirlpool Washing Machines
Washing Machines Logo
1,052 people viewed this question
Top Washing Machines Experts
