Texas Instruments TI-83 Plus Calculator Logo
Posted on Sep 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I find bionomial probibility? - Texas Instruments TI-83 Plus Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Sep 27, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428347
Points
622693
You'll find the binomial distribution functions in the DISTR menu (press 2ND [DISTR]).
Keyppad doesn't work
the keys are probibly pushed in the inside it is probibly gone abit deep so you'll have to get it repaired. good luck...
3helpful
2answers
My 1997 C1500 Chevy vent issue
Your blend door is probibly not moving all the way to vent position.If you put it on vent there is probibly air blowing on floor or defrost.It may also be opening just a fraction and causing back pressure on the blower motor causing the noise.Is there any difference in outside air or recirculate?
1helpful
2answers
Ford focus 2001 reverse light does not work, ive changed the bulb and checked the fuses and still does not work. the bulb i took out hasnt blown but is black on one side. can you help
I found that water had got into the connector and was damp so i took the bulb and casing out from inside the bumper disconnected it and sprayed the pins with WD40, connected it back up and it worked. took less than 5 mins.
1helpful
I don't know where to locate my probability key for a bionomial probability.
The binomial probability functions may be found in the DISTR menu. Bring up the menu by pressing 2ND [DISTR].
Gauges
cluster is bad ; replace it circut board is probibly cracked
3helpful
I need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
1helpful
I have lost the back cover of my watch. Had a new battery put in and the first time I wore it afterwards , I noticed the back covering was missing. Can you send my a new back or advise where I can a
Alot of times the company will help you with this problem, get ahold of them first. If you have no luck there, fined yourself a reputable watchmaker who probibly will be able to fit one on for you. You are lucky it is a round back,any other would probibly be near imposible to fit. If you still have problems let me know . I have been a watchmaker for 24 years, my father was a watchmaker for 50, and my grandfather was a watchmaker for 50., between what I have gathered in 24 years and my family, I should be able to help. Good Luck!!
My nixon watch shows fogging on the inside after i wear it for a few hours??
The problem is that water or humidity is getting into your watch. You either need a new back gasket 9 probibly nicked when changing a battery, or your crown ( the little piece used to change the time) gasket is bad, or you have a crack in your crystal. Turn your crown as if to wind it , if it turns REALLY easy your crown gasket is bad, if not you need to open your watchback and insert a new gasket around the back cover. Make sure that it fits tight ( you probibly have to stretch it a little) and then reclose the watch. The only place I know you can get a seal is at a watch repair shop.
10helpful
2answers
BINOMIAL DISTRIBUTION
Let us start with a review of the formula for the binomial distribution
f(r;n,p)=n!/(r!(n-r)!)x(p^r)x(1-p)^(n-r)
But n!/(r!(n-r)!)=(nCr) you get
f(r;n,p)= (nCr)x(p^r)x(1-p)^(n-r)
Exemple : n=25, r=6, p=0.7
f(6;25,0.7)= 25 [PRB] [-->] 6 [ x ] {0.7[ ^] 6 }[ x ]{0.3[ ^ ]19}
The arrow means a horizontal scroll once to select the (nCr) function. [ x ] stands for the multiplication sign.
[ ^] is the raise to the power key
The { } are used here as parentheses to make formula legible.
Hoe it helps
Hope it helps
Hope it helps.
Leather Band
Do you need the same strap that was on it? The only way to try to get that is through Kennth Cole, and they probibly will tell you it is discontinued, but try. If you are not needing the exact band , take your watch to a watch repair shop, they will have bands that will fit your watch and probibly the style too. If you find you can't get what you want ,PLEASE let me know and I will do my best to find what you are looking for. Good Luck!
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
