Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Temp is reading HI so stove won't come on. Figure it is a thermostat problem(?)
  • 674 Answers
This means the room temperature is over 95F. This could be due to the sensor being in the sun or the sensor is shorted. Try unplugging the thermostat wire and see if it goes away. If it does you may need a new thermostat wire.
Posted on Nov 22, 2010
How do i check the thermostat in my dodge caravan
remove the thermostat from the engine. You will need a thermometer or some other device to read water temp. hang the thermostat in a pot (Placing the flange at water level) and place on the stove or some heating device. bring the water to the boil while watching the thermostat. As the water temp approaches 80-85c you will see the center of the thermo start to open. As the water approaches the boil thye thermo should be fully open. Check you readings (start to open and full open) with the specs stamped into the body of the thermostat. If they are the same the unit is ok. If it opens too hot or dosen't fully open buy a new one . If It is fully open when cold buy a new one.
Jan 21, 2013 | 1997 Dodge Grand Caravan
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
I moved into a new flat and the AKP 239/01 IX stove was already built in and there is only user manuals in every other language except English!! The owner does not have it and no-one knows where it is! I...
google -- user manual for ( make and model of stove ) and download the pdf version
failing that go to places like Jaycar and buy an infrared thermometer
you aim this unit at where you want to read the temperature and it reads it
so aim it at the oven glass and you have the temp
or aim it at a hot plate and you have the temp
Sep 08, 2017 | Whirlpool Ovens
A customer has a commercial propane gas stove,
Faulty thermostat, can be the only reason if the burners on the top are okay and don't fluctuate. That proves your regulator is fine. You could also check the line somewhere with a pressure gauge, or manometer.
Sounds like they need a new rep. Contact the company's service department. These guys have often come across the problem before, "oh yes, we had a batch of thermostats that had faults about 4 years ago. We didn't do a recall because it wasn't a safety issue". Meanwhile, the rep is only after sales and commission.
Aug 08, 2017 | American Range ARW36-6 Stainless Steel...
1998 g e self-cleaning stove , oven temp.
got rid of this used junk,and bought a new stove.
Mar 27, 2009 | GE Kitchen Ranges
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Coolant bizarre behavior
if car doesn't run hot with no thermostat...you may be air-locking system when installing thermostat. I always fill the engine block up to the thermostat housing to make sure that engine is full of fluid ..then install thermostat...spring facing down..thenfill radiator making sure car is running so as not to air lock system ...run until top hose gets warm ,showing that your thermostat opened
Nov 23, 2008 | 1998 Chevrolet Cavalier
Renault safrane heater problem
hi is the temp gauge registraring normall reading if not thermostat will be stuck open yates210456
Aug 11, 2008 | 2000 Renault Sportwagon
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
54 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
