Question about Moen Home
DeiNew kitchen faucet ,when you first turn it on water comes out foamy,has a slight taste
  • 22 Answers
Hook it up to a beer tap!
Posted on Sep 28, 2010
Tuscany kitchen faucet
The hose is always filled with water when not in use. The longer that water remains stagnant in that line, the more it will absorb that smell. Try running the water for 10-15 seconds before filling your glass. If that doesn't solve the problem, purchase a new hose.
Oct 20, 2013 | Plumbing
Sour smelling/ tasting water from bathroom faucet when not used for several hours. Smells like traces in water bottles, which I can bleach or wash in dishwasher. How do I clean possible bacteria from a...
Assuming the problem is right there at the faucet, and not further upstream (which you could verify by taking a little water from the tub faucet), perhaps you could try this--- turn off the water supply then remove the flexible water supply lines from the faucet underneath the sink. These are usually not too hard to remove from the faucet with a basin wrench (less than $10). If it's easy, remove the other end of the flexible water supply lines too. Maybe you should replace these. Otherwise, get the water out of those flexible line, then put some bleach into them. Reconnect to the faucet. Leave the faucet turned off, and turn the water supply back on. Then very slightly turn on the faucet to allow the air out, then turn it off. Leave the bleach to soak for a while (maybe 30 minutes) then flush plenty of water through it. If the smell comes back, there is probably something organic stuck in the faucet and you will have to disassemble or replace it. Good luck.
Dec 20, 2010 | Home
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
We had a new kitchen faucet put in today and the water tastes terrible now. Can we do something?
Nothing other than let the water run at 1/4 throttle in an attempt to clear the nasty tasting water from the supply lines. Let it run for maybe an hour and taste it again.
Working on the lines might have shook loose the foul taste way back up the system. I would hope an hour would clear it but it may take more.
Some cities with less than perfect water will flush their supply lines by opening fire hydrants in a certain pattern designed to shake loose deposits from inside the supply pipes. They often report that people have bad tasting water for days afterwards - perhaps in a few days you might get your relief too?
Aug 04, 2009 | U-Line BI-95
Bad taste and smell in water at kitchen sink faucet
Check your water filter inside the unit up in either the left or right side of the top. If you do not have a filter then add a filter to the unit on the supply line to help with this problem
Feb 22, 2009 | U-Line BI-95
Unable to loosen and unscrew kitchen faucet screen...
If you have a lime problem, try soaking the tip in boiling water with vineger added to it. The acetic acid in the vineger disolves the lime. I did it just last week when I serviced my kitchen faucet. It may take quite a while for the lime to disolve, but in the end you will achieve your goal.
Jan 07, 2009 | Danze Fairmont Double Handle Roman Tub...
We are getting a metallic taste and smell
The metalic taste is coming from the the new faucet
I would call American Standard and ask them if they have any complaints for this particular model
I would run hot water through the faucet for 5 minute intervals
If it persists I would take it back and demand a refund or cal AS and demand a refund or replacement model
I am sure the local news would like to report something like this
Jan 05, 2009 | American Standard Kitchen Faucet 6310 020...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Home Logo
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
