Question about GE Refrigerators
The fridge has power. But the temperature control has no power. I have a G.E. side by side. model # gss25tgpa
  • 172 Answers
Hi Frank,
I would imagine you searched your refrigerator for a defrost timer and did not find one. Your refrigerator does not have a defrost timer. You have a control board located on the back of the refrigerator. Item number WR55X10552 If you have not power to your controls, try unplugging your refrigerator for 5 minutes. Plug the refrigerator back in and check again for power. If you have no power replace the control board. Hope this will fixya. Mike Anderson
Posted on May 24, 2008
  • 828 Answers
Check the defrost timer. It may be stuck in the defrost position which would give you no power to the temperature control. Locate the timer and rotate the clutch head screw clockwise and you should hear a click after which the compressor will start and there will be power to the thermostat.
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
There fridge side is freezing everything!
Hi
What is the model of your fridge.
On the older fridges, a faulty thermostat would cause the fridge compressor to run continuously and therefore, would not regulate the temperature.
On newer electronic models, you have temperature sensors giving signals to the control board. These can fail.
Ash
Sep 11, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerator side is not cooling enough. Temperature is only in low 50's. Freezer side seems to be okay.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Dec 28, 2009 | Refrigerators
Fridge wires cut
The answer could well be Yes. Ideally you should reoplace the harness anyway. The fridge controls and air valve shutter (see below) will also be wired via the harness.
Nov 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
My Whirlpool side-by-side model-ED20ZKXBW00 MFG date is 9-94. Freezer portion works great and refrigerator part is now barely cool so I have spoiled food. What could be causing this?
Nov 10, 2009 | Whirlpool 19.8 cu. ft. Side-by-Side...
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Not cooling
there is a three prong relay that runs to the compressor that may be bad or the compressor itself has gone bad.
Jan 12, 2009 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Refrigerators Logo
260 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
