Question about Dryers
MY AMANA DRYER HEATS UP BUT DOESN'T DRY CLOTHES
    Sergeant:
    Champion:
  • 351 Answers
Check the vent may be stop up or blower wheel loose
Posted on Sep 27, 2010
  • 205 Answers
Hello- It sound like a very common problem and one that you may be able to remedy yourself. It is likely that the dryer is not venting well and the hot moist air is not getting out of the dryer thus taking longer to dry.
  • Check the venting at the back of the dryer and make sure the flexible duct is not crushed or crimped. If it is then you can replace it (you can get 4" dryer duct from most hardware stores). Even if it looks ok you should remove it from the dryer and the wall and see if there is a lot of lint build up inside.
  • Turn the dryer on and go to the exterior of the house where the vent comes out of the exterior wall and feel how much air is coming out. It should be blowing pretty hard like a fan would. You can also feel inside the vent if possible and see if you feel a lot of lint. Some vents have a little cage over the end to prevent squirrels from getting in there and that can be removed and cleaned. If the air flow is low then you may need to have a duct cleaning service out especially if the vent runs a long distance inside the wall and had many bends.
  • A good way to test if the venting is a problem is to run the dryer with the vent detached from the wall inside. It is best to put pantyhose over the end of the duct to prevent too much lint from filling the room.
Hope this helps, best regards.
4 Suggested Answers
  • 1564 Answers
SOURCE: Dryer heats up but doesn't dry clothes...
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Posted on Sep 12, 2012
  • 57 Answers
SOURCE: dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Posted on Jun 24, 2008
  • 15 Answers
SOURCE: Dryer air heats up but does not dry the clothes. Just replaced the timer but did not fix the problem. Air vents are cleared.
One of two possiblities:
1. Dryer vent is blocked - check the air coming through the outside vent
2. Blower Fan is clogged - remove the lower front panel and clean out the fan wheel
Posted on Apr 30, 2009
My Amana gas dryer Model NDG7800AWW heats initially and then stops.
Hi Mohit , you need a new set of valve coils . It's part # 5303931775 GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Amana NDG7800AW Gas Dryer
Dryer heats but won't dry clothes completely
Inspect and clean the dryer is what I would do. most times it is a faulty blower wheel causes your symptoms.
Feb 16, 2013 | Amana Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
Heats up but takes several cycles to get clothes dryer
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Aug 08, 2010 | Amana NED5400TQ Electric Dryer
Electric dryer heats up ,but takes 3 or 4 times on very dry hot setting or timed setting to dry clothes?
Check vent for restrictions including pushing dryer too far back on vent.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
My Amana gas dryer won't heat or dry clothes.
it's either that or gas valve solenoid
Mar 01, 2009 | Amana Dryers
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer leaking water
it sounds to me like the heating element that heats up to dry the clothes has gone faulty or tripped out. Cant really tell from here.. when you open the drier is there a good level of heat ? If not, its the heating element section at fault.
Mar 17, 2008 | Dryers
Dryers Logo
569 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
