Question about Carrier Beverage-Air UR30GEFD Beverage Cooler
My Bev Air UR30G runs, but only warm air comes out...how can I fix?
What is the proper way to charge freon to the beverage air (mm14ge)
Posted on Apr 30, 2012
    Sergeant:
    Champion:
  • 351 Answers
Make sure the compressor is running if not check the thermostat. or could have leak and lost coolant
Posted on Sep 27, 2010
Looking for the wiring diagram for a UR30G fridge
Just because the compressor checked out okay doesn't mean that the overload and relay doesn't need to be replaced it also could mean that the compressor is mechanically defective I would try by installing a URCO810RC 4n1 relay kit. It is all you need no sense in wasting money on new parts if your refrigerator does not have the run capacitor do not install the one that comes with the kit
Supco
Aug 30, 2016 | Carrier Beverage-Air UR30GEFD Beverage...
Delfield vs bev air, which way would you go for a used 2 door under the counter refrigerator in a concession trailer?
I'm not a big fan of either. I've been involved in the restaurant business my entire adult life and neither one impresses me. If I had to choose, it would be the Delfield but keep in mind that their parts have to come from a Delfield supplier. Bev-Air parts are a little easier to get except for things like door hinges and door gaskets. Sorry that I can't really be much more help than this but this is my opinion based on experiences.
Feb 07, 2011 | Delfield 64'' Refrigerated Sandwich Table...
I have a Bev Air MT-27 cooler for home use. Is it possible to have it rewired so it functions more like a refrigerator so the fan doesn't run 24/7? And if that isn't possible, could I use a timer so that...
On commercial coolers, the fans are designed to run 24/7 to prevent the coils from freezing up. If the unit only runs 4 times a day, it will not maintain proper temps. Domestic units utilize the freezer compartment air to keep the refrigerator section at temp. Totally different set ups. I wouldn't do what you are suggesting with a commercial unit.
Nov 23, 2010 | Beverage-Air MT27 Beverage Cooler...
I have a Beverage Air cooler (Model UR30G) where the fans seem to be running, but only warm air comes out...it's about 10 yrs old and is in great looking shape and would love to find a way to fix....any...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 26, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
I need to buy a new thermostat where can i find one for a beverage air ur30g
I believe there are many of the same part that would work for you. But I will give you the link direct to=> Beverage Air
Knowing them they will want the serial number also. Hope that is helpful, Sea Breeze
Nov 19, 2009 | Refrigerators
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
Beverage air dd58 kegerator won't stay cold
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Jan 12, 2009 | Beverage-Air DD58 Beverage Cooler
I have a commercial Bev-air refrigerator that will not cut off when it reaches the set temp. and when dial is turned to off position it will also not turn off.
Sounds like the t'stat is bad. Inside are contact points that can "Weld" together causing this condition. Possibly wired wrong but I doubt it if it has worked in the past and no one has worked on it. Should be an easy fix. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick.
Dec 30, 2008 | Freezers
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Oct 09, 2008 | Beverage-Air 23.1 cu. ft. / 654 liter...
Carrier Beverage-Air UR30GEFD Beverage Cooler Logo
632 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
