Question about Maytag Refrigerators
I have a Maytag Model # MSD2957AEB side by side refrigerator and the coils in the freezer part each month seem to freeze up. This causes the cold vent leading to the refrigerator to stop the cold air flowing into the refrigerator. Each month I need to open the freezer side remove the back cover and defrost the coils. I assume it is the defroster not working correctly. Is the defroster the small cylindrical metal piece connected to the defrost element or is the defrost mechanism somewhere else?
    Sergeant:
    Champion:
  • 351 Answers
The metal piece is the defrost terminate thermostat the adaptive defrost control is in the food side .top where the control are and lights . on the right not hard to miss
Posted on Sep 27, 2010
My Admiral freezer is cold but not freezing. The fridge seems fine but food in the freezer is thawing.
See if the coil is clean, if not, vacuum and brush the coil clean.
That should make diagnosis much easier.
Jan 09, 2011 | Maytag Admiral Top-Freezer Refrigerator
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
My refrige runs but tne freezer stopped freezing and eveything thawed ,also ice machine . my refrige part seems to be fine
tempt in freezer is or should be 15 deg or lower to 5deg/ the ref gets its cold from the freezer . so if freezer is failing the soon so will the fresh food side . look for ice (frost build up on the back of freezer . / and if so the cold coil is blocked and there is no air flow through it .. if you find this you have a defrost system failure . ck the heater in freezer and the defrost terminator and the aditive defrost control . these are the things that cause this problem. A D C is most common .. hope this helps mm
Oct 11, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
Why is my condenser freezing up, but my frig isn't cooling right? could it be the thermostat? Or is the condenser flooded?
when the evap ( the coil inside the freezer freezes up it blocks the coil causing no cold air to flow to the fresh food side. . the thermo is ok but the aditive defrost control or the heater or defrost terminator is or has failed .. mm ( you do have a defrost problem .. mm
Aug 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Maytag
Heres you problem your drain plug in freezer is likely frozen as well and water is running under fridge. You have to replace the thermostat defroster assembly Its behind the panel at rear of freezer and runs down and under condenser coils. Part cost $42 and plugs in its easy to replace It creates heat which keeps the coils free of ice and also keeps drain from freezing.
Jun 19, 2008 | Maytag MSD2756GES Side by Side...
Freezer not freezing
Check the back wall of the freezer section for signs of frost build-up. If the freezer coil is frozen from a fault in the defrost system your refrigerator will be the first to show signs of not cooling.
Dec 11, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Refrigerators Logo
111 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
