My RCA projection tv p46924YX2 went dead, i replaced the small fuse in the back and now the convergence is off
  • 520 Answers
Many RCA tv's have a convergence adjustment in the menu options.
Posted on May 24, 2008
  • packparty Feb 28, 2011
    Is there a manual adjustment,not in menu options rca p52945 11yrs old
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try Ebay.com to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
HI my name is eric. my color on my rca 54 tv off how do i line it up
This tv have problems known as a convergence problems,it dead.The tv colors lines R,B,G mis alignments,have colors shadows or 3D pictures alike?U must have tools like a soldering iron,a desoldering pump or a roll desoldering braid,a roll of solders?Can u also do basic soldering?This RCA DLP tv used covergence FUSES.Yes,try Ebay.com to buy a convergence FL231 convergence fuses there are three of them the one middle useally alway dead.After replacing the FL231 Convergence fuse,near there a big black block of plastic that call the FBT,the high voltage tranformer.Resolders the FBT too.Will solved this problems.Or the tv shop,will cost like 200-300 for parts and labors.
Dec 28, 2010 | RCA HD52W59 HDTV Projection Television
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a 52" projection tv went blank the other night came back on and now is showing a double picture
Tv have a problems known as a convergence problems,it dead.The tv convergence board.The 2 STK convergence ICS and some or all the resistors are dead.These parts are dead,must replaced to solved the covergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | RCA D52W136D 52 in. TV/DVD Combo
P52921...TV was dead. I turned it off last night no power this morning small fuse was blown and I replaced it and cleaned very dusty lens and hard reset. Now TV is not showing on entire screen but has a...
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resistors,must be change to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 28, 2010 | RCA P52921 52" Rear Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
