Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have 2 lines of blue pixels on my Sony Bravia. One line is about 4 inches and other about 1 inch. How do I go about fixing this before the problem gets worse?
    President:
  • Sony Master
  • 1,114 Answers
This site would be the best place to start. Sony has had many issues like yours since 2004 to current model SXRD LCD TV's. The main culprit seems to be the
optical block, however, it;s not just limited to that. Take a look at this site,
it has more info in one location including contact #'s at Sony for help. Hope
this eases the pain!
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Posted on Sep 27, 2010
Model# kdl-40w4100 Serial # 8051767 2 years old Horizontal lines in 4.5 inch blocks at the top of the screen
I have the same tv model KDL-40W4100 and around the same age. At the moment I have 16 of
these horizontal lines over the entire screen and they seem to be grouped into 2 lines per row. They are also around 4 inches and two pixel rows high. I have been looking over the Internet for months and found nothing to troubleshooting this issues. In the last few weeks more and more of these groups of lines have been showing up and now i am up to 16 of them and it is becoming unwatchable. Any help from anyone would be greatly appreciated. I also attached a picture to describe it better. Thanks!
Nov 06, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I have a Flat screen Sony Bravia KDL-46S4100. Lines go across the screen horizontally about 6 inches apart. There is distortion especially on the right side mostly on lower right. What needs to be done to...
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Apr 02, 2010 | Televison & Video
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KVL-V40A10 - pixelated lines top and bottom of screen
Are these lines visible regardless of what device (DVD player, cable box) you are watching?  If so, then yes, it appears the LCD panel is failing.  If you only see the lines watching one device, it could be the cable/wire or the device itself.  Now it can also be the related input jacks too so connect the device to another input to be sure.
Mar 24, 2009 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Nov 21, 2007 | Sony KDF-E55A20 55 in. LCD Television
Line on screen
It sounds like the actual LCD is damaged, i've seen some cases where it was a damaged cable going to the LCD screen but if the cable looks ok then it is probably the lcd screen.
Nov 09, 2007 | Fujitsu P55XHA40US 55 in. Plasma...
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
224 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
