Question about Panasonic Lands Phones
How to reset answer phone message to the original
Answer light stays on all the time on my office phone
Posted on Sep 28, 2010
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
When making a call or answering a call the mobile battery level comes down and showing battery low and get switched off
I had the same problem.
If your battery is not a Original Nokia (Genuine) Battery,then you must replace it with a genuine Nokia battery.
If the problem remains,then you have to Reset your phone
How to do it :
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Dec 21, 2010 | Nokia N70 Cellular Phone
How can i restore my original font?
Try to reset your phone :
Method 1: Three Finger Reset for Nokia Phone ima111_8.jpg 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message. Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
Dec 06, 2010 | Nokia 6600
My nokia 5800 express music receives late messages
Perform a hard reset on the phone: Turn phone off. hold reject call button, answer call button , camera button and turn on. keep holding untill the nokia hands show then just follow the original setup. Make sure u back everything up as it will all be lost.
Feb 21, 2010 | Nokia 5800 XpressMusic Smartphone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Resetting answering machine message, lost instruction manual
goto this wepage put in your model number and you can download your replacement manual.
http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults
Resetting will return most functions to the original factory default setting.
Registrations are not affected by resetting.
1. Press Menu.
2. Scroll using v/V to Base Set. Press OK.
3. Scroll using v/V to Default Set. Press OK.
4. Enter your current base unit PIN code (0000 at default).
5. Press OK to confirm.
Dec 10, 2009 | Doro DECT 850 Cordless Phone
Phone answering machine
Moving a Message to Another Mailbox
You can move a message from one mailbox to another. The message is saved a a new message in the mailbox to which it's been added and is deleted from the original mailbox.
1 While the message you want to move is playing press "setup". The system beeps and stops playback, the Message Window displays CP (for copy) and the Mailbox lights flash.
2 Press the MBox button where you want to move the message. The system resumes playing messages in the original mailbox.
Aug 10, 2008 | AT&T 1726 Digital Answering Machine
Message display
In the even your new voice message alert flashing gets out of sync with your phone company's voice messaging system, you can reset it bact to the original "no messages waiting", non-flashing state. To do this, with the phone in the standby mode and in its cradle, press and hold find hs (find handset) on the base until the paging sound stops (about 5 seconds). The flashing will stop.
Apr 19, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Lands Phones Logo
65 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
