Question about Brother CE5000 Computerized Sewing Machine
I cannot tighten the bobbin tension, - Brother CE5000 Computerized Sewing Machine
  • Brother Master
  • 7,365 Answers
The screw on the bobbin case- to the left tightens
to the right loosens
Posted on Sep 28, 2010
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
What adjustment do you need to make when the bobbin is throwing too much thread out.
Your tension is is too loose somewhere I guess, so will need tightening. Tighten the upper tension first to see if that helps before tackling the spring on the bobbin. If you need to tighten the spring on the bobbin then do it in tiny increments and remember where you started. Try taking out the bobbin and gently pulling by hand the thread from it; it should have a slightly tight feel on the correct tension..
Oct 01, 2015 | Sewing Machines
Advice on how do I adjust tension
I don't have a Janome, but in general
if your seam has extra loops at the top
looks like ^-^-^-^
loosen the upper tension a bit and tighten the bobbin tension a bit.
If the extra loops are at the bottom
sort of like \/-\/-\/-
do the opposite - tighten the upper tension a bit and loosen the bobbin tension a bit.
The upper tension is easy; it's usually a dial with +/- numbers. The bobbin may be more difficult. For mine, it's a screw on the side of the bobbin case. A web search seems to indicate Janome is the same.
Practice on scraps of the same weight and use the same thread you're using on your project until you get the tension right.
good luck
Oct 03, 2014 | Janome Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
HOW DO YOU TIGHTEN THE BOBBIN TENSION ON A SINGER 717
There is a screw on the bobbin case which you turn clockwise to tighten but on a quarter of a turn at a time then test sew, make sure the bobbin turns antil clockwise in the bobbin case.
Jul 22, 2010 | Singer Sewing Machines
Bobbin tread is loose when sewing on cotton material Have adjusted tension, it is on 9. It is fine when I sew denim, which I sew a lot but I am trying to sew cotton now. I have cleanned machine, changed...
Have you checked not only the top tension but also the bottom (bobbin) tension? Top tension is usually a lever wheel etc on the machine (depending on model). To tighten the bobbin tension you need to tighten the small screw on your bobbin casing.
I don't suppose it could be as simple as this?
Jul 07, 2010 | Kenmore Sewing Machines
Bobbin tension is too loose
On the bobbin case there are two screws, make sure the bobbin turns anti clockwise inb the bobbin case as you look at it, turn the larger screw clockwise to tighten the tension about a quarter of a turn and test, keep adjusting until you get it right
Jun 23, 2010 | Necchi 3537 Mechanical Sewing Machine
Is there a way to tighten the tension on the bobbin?
In checking things out, I determined that the bobbin was incorrectly threaded into the bobbin holder. After rethreading correctly, and tightening the bobbin tension just a little bit, the machine worked perfectly. Thank you for checking back, I appreciate it very much. D
Feb 03, 2010 | Kenmore Sewing Machines
The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Nov 04, 2009 | Husqvarna Designer I
Brother CE5000 Computerized Sewing Machine Logo
59 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
