Question about Carrier Commercial Freezer CFG48
My freezer mod#ULG80BC-5 every morning the disply
My freezer mod#ULG80BC-5 every morning the disply reads E7 I have to restart to maintain temprature what E7 means and if i can get a technical support manual?
  • 316 Answers
I dont provide refrigerator repair service on commercial units, but my first instinct is to say that E7 is an error code message, likely pertaining to a self diagnostic system, but you would also likely need the manual to determine the source of that error.
Posted on Oct 05, 2010
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Need to adjust my temperature differential on my carrier pulse freezer mod#ULG50BC-5
Is this a digital or standard model . That helps me in figuring this out.
Mar 01, 2013 | Carrier Freezers
Freezer lffu14f54hwc try to cutoff by holding down till 0 appears get e7 appearing
Hello Oran - Typically error code F7 on Frigidaire freezer indicates that the unit has detected a stuck key or fail safe mode initiated. Check if it has a thermistor failure and may possibly need to replace the main control board. Contact a professional to move forward accurately.
Oct 12, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
My kenmore mod#2539183511 chest freezer comes on @30 sec goes off for @3-5 sec tries again.Need diag help or wiring diagram.
Sorry to read about your problem. you can have many different problems.
a wiring diagram will not help you in this case. all 3 items below at at the compressor.
odds are you will have to have the compressor replaced.
1. Failing compressor
2. Defective start cap
3. Defective overload protector
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Jan 02, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
There is a switch on the bottom under the door by the floor vent thing, and a light on both sides of it, what does this switch do?
That switch allows a temprature alarm to work or not to work depending on which way it is switched. That way you have time to move your contents when the temprature gets above freezing in the freezer. Please make coment and rate me and my knowledge if this answers your question. Thanks
Sep 05, 2010 | Kenmore 17.1 cu. ft. / 484 liter Upright...
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Frigidaire Mod FFC05C2AW1 freezer won't cool, hear something running, the light over the thermo. isn't on either. Any ideas?
please switch off your refrigerator for at least 5 hrs. than again switch it on. if your problem is not cured than it is sure that you have your gas chockage....... please visit your service authority
May 13, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Carrier Commercial Freezer CFG48 Logo
369 people viewed this question
Top Carrier Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
AJMAL KHAN
Are you a Carrier Freezer Expert? Answer questions, earn points and help others
